    LOOP SELECTION PLUGIN?
    16 Posts 9 Posters 3.6k Views 9 Watching
      taoklai
      I was working on a big scale architectural model and i realized how great it would be if there was a LOOP SELECTION plugin in SU like in other modeling softwares...so i wanted to ask if there is something similar? 😄 if there isn't i'd like to propose it for future scripts 😄 thx 4 reading
      • bagateloB Offline
        bagatelo
        I also wait for tool to make loop selection. In Modo, loop selection is perfect.
          Jim
          How about an example of what you mean?
          Faces in SketchUp have loops already - one outer loop, and possible inner loops if there are holes in the face. Selecting these loops would be trivial as they can be retrieved using the Ruby API.
            I guess he's thinking on something similar to what you get in Modo. Right?
              taoklai
              hmmm....i mean LOOP as LASSO SELECTION - if you select a face (let's say on a RUBIK'S CUBE model) and you hit LOOP, this should select all vertical faces (given that the cube is placed normally on a horizontal plane), and if you would hit LOOP again it should select all the faces in the other direction (without selecting the edges). And it should do the same for when you select a line (it should select all lines - like a lasso - on the line's direction and close back with the same line)
              http://i529.photobucket.com/albums/dd333/taoklai/ex1.jpg
              http://i529.photobucket.com/albums/dd333/taoklai/ex2.jpg
              http://i529.photobucket.com/albums/dd333/taoklai/ex3.jpg
              • EarthMoverE Offline
                EarthMover
                This is a much needed plugin for me. It would speed up the process of my modeling a lot. Most major modeling applications have a loop select, or a loop select plugin.
                How it usually works is that you select a face or line and then select another face or line in a specific direction. The second selection will tell the tool which way and on which axis to run the loop. The loop continues selecting until it reaches the original selection.
                Would this be possible in Sketchup with a ruby??????? PLEASE???
                Also, once a loop is selected, it would be nice to be able to grow the selection by means of the up and down arrows.
                This would be one of those tools that people wonder how they ever lived without!!
                Content Creator at Skapeup
                • W Offline
                  wikii
                  LoopSelector
                    EarthMover
                    Wikii, you mind sharing the ruby? It looks like exactly what we're talking about. Will it select an edge loop as well?
                    • bagateloB Offline
                      bagatelo
                      Some improvements.
                      DootLoop:
                      http://www.polyboost.com/Images/Gifs/DotLoop.gif
                      http://www.polyboost.com/Images/Gifs/DotLoopE.gif
                      Loop
                      http://www.polyboost.com/Images/Gifs/Loop.gif
                      http://www.polyboost.com/Images/Gifs/LoopV.gif
                      Ring
                      http://www.polyboost.com/Images/Gifs/Ring.gif
                      http://www.polyboost.com/Images/Gifs/RingV.gif
                      OutLine
                      http://www.polyboost.com/Images/Gifs/Outline.gif
                      http://www.polyboost.com/Images/Gifs/Outline2.gif
                      Tops
                      http://www.polyboost.com/Images/Gifs/Tops.gif
                      Similar
                      http://www.polyboost.com/Images/Gifs/Similarmulti.gif
                      Step Mode
                      http://www.polyboost.com/Images/Gifs/StepMode.gif
                      Select Half
                      http://www.polyboost.com/Images/Gifs/SelectHalf.gif
                      Distance Select
                      http://www.polyboost.com/Images/Gifs/DistSelect.gif
                      Perspective Grow
                      http://www.polyboost.com/Images/Gifs/PerspGrow.gif
                      Perspective Select
                      http://www.polyboost.com/Images/Gifs/PerspSel.gif
                      More here
                      • bagateloB Offline
                        bagatelo
                        Another Improvements:
                        Please See "features" here:
                        http://www.orionflame.com/
                        These two plugins for 3dsmax (orion flame and polyboost) have fantastic tools for modeling, beyond selection.
                          EarthMover
                          Any word on this? Does anyone know what it is the Wikii is using in his post?
                            taoklai
                            indeed, Wikii's "loopselector" looks awesome - exactly what we need 😄 - please upload
                              ScottPara
                              Agree this would be a great plug in to have. PLEASE upload.
                              Scott
                              Love the fact that some HATE my avatar.....
                                REGIS
                                Nice one wikii
                                Does it works with triangulated faces ?
                                regards
                                  FYI, a very basic, and very beta version, of a loop tool can be found here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14975&p=114429#p114429
                                  I was just playing around today with some other selection tools. Not sure if I'm doing this selection effectivly though. If any of the more experienced scripts would like to jump on this it'd be great.
                                  • Y Offline
                                    Yanman
                                    Wow visit. 💭 💭
