    Formulaes and DC behaviour
    13 Posts 3 Posters 2.4k Views 3 Watching
    • D
      dagfinnie
      I have tried to add a formula in the parent component which calculates let's say the length of a joist times the number of copies in a subcomponent. The number turns out correctly. So far so good. But if I now try to stretch the main component, it's not working properly anymore. To me it seems there has been a disruption in the connection between the parent and the the child because of that specific formula, even if no other parameters have been changed. (Except for the calculation formula). Has anyone of you experienced the same thing, and is there a logical reason for this to happen?
      I have tried different approaches to solve the problem, but have failed so far.
      • Chris FullmerC
        Do you have the model as an example? And please label which is the joist πŸ˜„ Thanks,
        Chris
        All my Plugins I've written
        • D
          dagfinnie
          Hi Chris.
          Here are two models, seemingly the same. Model.skp holds no formula in the parent component, while the other has a formula calculating the cost of the joists. The parent component contains 2 levels of nested components. Level 1(test) contains the floorjoist component and 4 wall components.Upper level(TrussWallFloor) contains the test and the
          TrussComponent. In Model2 you find an attribute with a formula called CostJoist2 which holds a value from the test which again holds a value from the FloorJoist component.
          The overall idea with the component is to scale the floor, the walls and the roof trusses in one operation and calculate the cost of each component at the same time. Obviously not so straightforward as I presumed. Try to scale the two models and see the difference in the joists. It is important that you scale the component in a cc 600 increment.(follow the grid.
          Dagfinn
          File without parent formula
          File with formula
          • Chris FullmerC
            Sorry if I'm particularly dense. I am trying and we'll figure it out.
            So in your models, the first one worked just fine as far as I could tell.
            The 2nd one has scaling issues. The floor joists and getting messed up upon scaling. And you're saying the only difference in the 2 files is that the 2nd one, that messes up, has added the cost function. So it seems that the unrelated cost function is actually messing up the scaling ability.
            Is that what the problem is? I'll explore that for now unless its something different.
            Chris
            PS you can make it snap to increments of 60 automatically by using something like this in the lenX
            LenX=round(current("LenX")/60)*60
            So say someone scaled to 310. That is the "current("LenX")" value. It gets divided by 60, which is 5.1667. That gets rounded down to 5. Then multiplied by 60 to go back up to 300, which is divisble by 60. So the LenX entered in the scale command of 310 gets forced down to 300. Hope that helps,
            EDIT: Of course I just tried this with no luck whatsoever in your model. It seemed to break the model. I'll try to see if I can figure out whats going wrong, but I don't promise anything. Joists and trusses are foreign territory for me πŸ˜„
            Chris
            • Chris FullmerC
              oh yeah, I remember playing with your model last time you uploaded it and I found out there is a problem with it saying it is it working in CM, but it appears to be workin inches actually. When it gets scaled, the value being returned is in inches. So to get my formula above to work, I had to divide by 60/2.54 to convert it to inches. Its very odd behavior and I'm not sure if its a bug or working as intended. But enter this formula in for LenX and it should now stick to 60cm increments on its own.
              =round(current("LenX")/(60/2.54))*60
              Of course this does nothing to help answer your original question. I'll keep working on that.
              • D
                dagfinnie
                Thank you for all help.
                You are quite right regarding the problem. Establishing a formula in the parent causes scaling problems. I will try to investigate it further, but right now I don't have a solution to this odd behavior. Thanks for the tip on the increment formula, I will try that one later.
                • Chris FullmerC
                  Hmm, ok so I tried taking your model #1 and merely adding custom attributes to get the sum value up to the main component and sure enough, it breaks the component.
                  This is not normal behavior. And if it is reproduceable from scratch, in a new model, this behavior should definitely be submitted as a bug.
                  • D
                    dagfinnie
                    I have tried several times to retrieve values from subcomponents in a formula in a parent, and every time I do this I encounter scaling/copy problems. It seems to affect the scaling/copy function directly in the sub you are linking to in the formula and nothing else. If this is a bug, it should be corrected because it is a really powerful feature that should work properly. If you refer to a parent value in a subcomponent everything works smoothly but not vice versa. Could you submit this further? Is there anyone else having some ideas?
                    • Chris FullmerC
                      OK, so I just tried to recreate your problem from scratch in a model set to CM and the component set to CM. WOW! I'm having lots of problems. Very much screwey behavior. I'll see if it is the same in an inches model.
                      Ok, so I couldn't get it to go wrong in an inches model. So then I went to reproduce it again in CM, and I couldn't get it to go wrong again. But I do have some ideas about what I might have done differently. So maybe tomorrow when I am more awake I can try some more on it. Good luck!
                      Chris
                      • D
                        dagfinnie
                        I keep forgetting that you Californian are 9 hours behind us. Thanks again!
                        • D
                          dagfinnie
                          I have rebuild my component using inches instead of CM, and the formulas no longer interrupt/distort the component as with cm. There is obviously a bug involved. It should be fixed. For the time beeing, the *2.54 will be me my way to the metric system. Thanks for that tip, Chris
                          • thomthomT
                            I second a request for a fix of this. It's very awkward to be forced to work with imperial units. At least for us metric people.
                            • Chris FullmerC
                              What could be akward about imperial units? We measure inches down to the 1/64, 12 inches in a feet, 3 feet in a yard, a lot of yards in a mile. Even more feet in a mile. Then theres also a lot of square feet in an acre, and a certain amount of acres in a square mile. And sometimes someone talks about hectares and I'm not sure if those are metric or imperial.
                              See, its just that easy.
                              I honestly google imperial unit definitions regularly when I have to go larger than feet and inches, and I have used the system my whole life. It could be worse though, it could be based on some ligical system of 10's or something.....
                              Chris
