    [HowTo?] Edit Components (or change "active level")
    6 Posts 5 Posters 1.9k Views 5 Watching
    • M
      MarcioAB
      Now, on SU7, that one can get the full "genealogical instances path" from your current "active level" up to the model level ( with model.active_path ).
      How can I re-position my "active level" in one particular instance of this path (kind of "edit level") ? Example:
      print model.active_path
      #Sketchup::ComponentInstance:0x01Sketchup::ComponentInstance:0x02Sketchup::ComponentInstance:0x03
      That means my current "active level" is instance 0x03.
      How can I move up one level using Ruby API to make my "active level" at instance 0x02 ?
      Thank you
      PS1: It could be a pair of APIs like this:
      model.get_active_path ( exactly the same as model.active_path)
      model.set_active_path(n) where n is the number of "levels" to go up.
      In the example above, model.set_active_path(1) will move the "active level" to
      PS2: Today I'm using the OUTLINER to get positioned in a particular "active level". How can I do the same using Ruby API ?
      Thank you
      Marcio
      • M
        Matt666
        Hi!
        I am also intersted by this request... How can you set active path to a defined componant instance?
        Frenglish at its best !
        My scripts
        • thomthomT
          Don't think there is one... 😞
          • J
            Jim
            Sounds like model.close_active is what you're looking for. You can "move up", but not dig deeper.
            Error 404 (Not Found)!!1
            (code.google.com)
            • M
              Matt666
              Yes I know this method... But not its opposite! 😞
              My scripts
              • TIGT
                model.close_active ### will jump you up one 'level' out of the current edit session.
                You can only go in the direction of the base model...
                You can repeat x(model.active_path.length) to close the edit back to the base model 'level'.
                Alternatively...
                model.active_path[model.active_path.length-2] ### to get up 1 level, or use -3 for 2 levels etc...
                All of these physically close any current edit sessions...
                If you just want to do something with the entities found at a particular 'level' then just use...
                parent=model.active_path[model.active_path.length-2]
                i.e. the container of the current edit session's instance/group
                parent_entities=parent.definition.entities if parent.typename=="ComponentInstance"
                parent_entities=parent.entities if parent.typename=="Group"
                etc... there's no need to close edits etc, just specify the actual entities-set to work on...
