    Create solid-appearing 3d models of a subsurface
    84 Posts 10 Posters 13.1k Views 10 Watching
    • G Offline
      gealagie
      Yes, I typed 200' and Enter, but it appears to get a little confused when you are standing 1860' below the surface! πŸ˜„ I'll tell you though, the Walk tool is the solution to being able to view features down in the "canyons". Before this I viewed and edited in those places by making groups obstructing my view invisible. Walk sets the camera without regard to what geometry is behind you. Dhuh! πŸ˜’ Like touring inside a building! Hey, I'm still an infant, okay?
        Yes, I can see that. πŸ˜„
        Problems with the walk tool may appear if you want to "jump" onto a higher level than 22" (a max./fairly high step height). That's why I meant it's more for architectural use.
        • G Offline
          gealagie
          Thanks for the advise, Gaieus. And thank you, Chris. Although I would like to very much, I may be unable to share the file of this stuff with you. This IS of a confidential oil "bidness" nature--and I really need the whereabouts of this actual geology keep secret (my personal info as well, Gaieus!). I don't want the Government of Madagascar, no, Corsica (Tasmania? Falklands?) to become upset that their area has been exposed.
          As it turns out I have a reprieve to a later date for the meeting I mentioned, so I can explore a few more things to better sell the idea of replacing 2d map representations of 3d geometry with solid 3d modeling.
          • daleD Offline
            dale
            I don't know if this has been mentioned, but have you tried using scenes for your presentation rotations?
            • G Offline
              gealagie
              That's a great idea, Dale. That's one more thing I have no knowledge of yet! I am looking for the video tutorial on scenes--I'm sure I watched on once before. I might as well explore that area and animations in general. Can you point me to a source?
              • G Offline
                gealagie
                So is an animation just a collection of still scenes? Like a power point presentation? Or can it be a true, continuous fly-through movie?
                  You should rather consider scenes as "control points" of your animation. When you right click a scene tab and choose "Play" (or export it into a movie), SU will connect the "control points" with a series of smooth transitions.
                  Note however that if you have problems with orbiting in your model, it will be jagged using scenes as well. There should be a "preload" function in SU to prevent this but there isn't.
                  • G Offline
                    gealagie
                    I'm discovering the jumpiness in my large model. It's not too bad, but definitely jumps to the new scene in steps, rather than continuously smooth camera flow. I think I'm getting the hang, but i don't see the place to save various animations (various collections of scenes).
                    • daleD Offline
                      dale
                      Scenes are actually fairly easy to use. I use them when someone else in our office is going to do a presentation without being present myself because they are fairly foolproof, so they don't get caught floundering around trying to make things work.
                      I think it should still work quite well even with your file size.
                      Drop down the "Window" menu from your menu bar, and select "Scenes"Picture 5.jpg
                      The "scenes" menu will be added to your desktop and should look something like the above.(I'm on a mac currently so it may be slightly different)
                      If you rotate your model to where you would like to start and press the "+" button (at the top of the scenes menu) it will add the scene. At the top of the SketchUp desktop you will see "Scene 1" will appear as well it will be in the Scenes menu as well.
                      Rotate your model again and find the second position you like and once again hit the"+" button in the scenes menu and it will add Scene.
                      You can add as many scenes as you wish to show the model.
                      Now go to the "View" menu in your main drop down menu, select "Animation" and from the drop down menu choose "Settings"Picture 6.jpg
                      This dialog box will allow you to set the number of seconds the scene remains static (Scene Delay), and how fast you move from scene to scene (Scene Transition)
                      You can play with these setting until you get the combination you like.To get the animation to work without manually clicking each scene, check the "Include in animation" check box which is in the "scenes menu"
                      This is really just the basics, and I hope I haven't confused more than helped
                      • daleD Offline
                        dale
                        Sorry I'm a little late as there have been several posting since my last one.
                        This isn't the best form of animation, but you can make some pretty simple and dynamic presentations with it.
                        • G Offline
                          gealagie
                          It's a very good overview, Dale. Thank you. I'm having fun with this. Now that question again: can I save multiple animations?
                          • daleD Offline
                            dale
                            Actually I'm not sure you can without creating separate files, but I'll do a little digging.
                            • daleD Offline
                              dale
                              I posted your question as a new topic in the discussion forums in case there is someone who hasn't been following this thread that can answer your animation question. I'm really not sure you can.
                                I have -and IMO it is not possible unless there is a plugin maybe.
                                • G Offline
                                  gealagie
                                  Okay, if and until something turns up it's save separate files to save different animations (messy but it works!). I'll probably just make one animation long and boring.... πŸ‘Ώ
                                  • G Offline
                                    gealagie
                                    Simple style, attached!
                                    • G Offline
                                      gealagie
                                      I will also tell you another thing I have done and why. This model is so large (I think 81,500+ elements), that at some point orbiting and panning would cause several of the groups (individual surfaces) to disappear which only their box-frames visible during the actual orbit or pan. The solution I tried seems to work--I can use the orbit, pan and zoon tools to guide someone through the model without this happening. What I did was save out a secondary, "presentation" file within which I then exploded every group in the model and regrouped everything together in one group. I know it's a dead end file with regard to significant additional model changes, but except for making some areas invisible (which is no longer possible in it), it seems to be fairly stable for demonstrating the geometry. I have no idea what unforeseen consequences I might encounter with it this afternoon! Can you think of any?
                                      • G Offline
                                        gealagie
                                        Pilot error again, sorry. I imported all these terrain surfaces at an earlier stage of SketchUnderstanding, and I see I have a few things associated to layers differently than planned. Now that I'm older and wiser, I'll watch more closely for those errors.
                                        I need to wrap this test project up soon. The plan now is to finish the geometry, apply smoothing to each of the terrain surfaces (which I've tested), apply color and/or some canned rock-like texture to them, and then render. Render--I'm not even sure I understand exactly what that encompasses and what possibilities exist. I assume it's basically light settings (multiple lights are possible, I hope) and allowing shadows and such. I envisage this "cliffscape/canyonscape" bathed in a warm morning light, but there are lots of nooks and crannies that should be properly illuminated should a viewer want to navigate into one of them to investigate. I'm not ready to buy a special rendering package right now--would like to exhaust what SU has to offer first. Any suggestions?
                                        • G Offline
                                          gealagie
                                          These are helpful, thank you. I was successful with tests of these workflows just now and got the results i wanted--when I was very mindful that the group from which elements to be moved (selected, grouped and re-assigned to the other layer) still resides on that original layer. I think I'm trying to add to your suggestions that you need to explode (or ungroup--that does mean the same thing as explode, right?)the group in the layer of origin (Layer 0) before reassigning it to the destination layer. Otherwise the reassigned elements are still in a group that's attached to layer 0 and will not be visible on the destination layer if the destination layer is the only one turned on. Am I making any sense? My project is pretty cluttered with close-fitting groups on different layers and I may have been afraid in the past to ungroup all these TIN elements for fear I'd never get the remainder back together in a group again! Truly in my mind a toggle switch to switch ALL layers on and off at once would be helpful on projects like mine.
                                          • G Offline
                                            gealagie
                                            Oops forgot the files.
                                            Gone. gone...
                                            • 4 / 5
