    Overly dark renders, and etcetera
    36 Posts 13 Posters 5.5k Views 13 Watching
    • boofredlayB Offline
      boofredlay
      Great renders.
      However, let me quote a line from those pesky Competition rules πŸ˜„
      -Sketchup output only (and as much as i know you love rendering your models, it would be appreciated if you could hold of posting them in the gallery until after the comp.)
        BTM
        Oh, I didn't notice that... but it's not in the comp section... so we can't even post them in the gallery?
        • FrederikF Offline
          Frederik
          Frederick: πŸ‘ . Also, how do I use volume lighting to create god's fingers without slowing my render down to 1% for 10 minutes?
          (I use KT)
          Volume lightning and soft shadows is a bad mix... πŸ˜‰
          Which also makes sence, since KT is a GI render application... πŸ˜‰
          Only use one of them at a time... Never together... πŸ˜‰
          click Settings > Scene...
          You'll now see a window with 3 tabs... (Lights, Cameras and Global Settings)
          Select the Global Settings tab...
          In the Ambient & Volume Lightning field, you need to check that Volume Lightning is ticked...
          In the Global Fog field you just need to adjust the Scatter settings... (you may start with .05 or .1)
          You can find a small scene here, which you can use to play with... πŸ˜‰
          Please note! ❗ Volume lightning will increase your render time significantly... 😐
          If you don't like longer render times, you can make Gods Ray in post pro...
          Cheers
          Kim Frederik
            boofredlay
            Correct.
              BTM
              so...do I remove them untill after the comp???
                boofredlay
                That is up to remus.
                  remus
                  I think leave them in place this time. I'm too lazy to copy them all and put them back in after the comp πŸ˜‰
                  Please dont do it again, though. If i'm in a bad mood theres a good chance i'll just delete the offending posts.
                    teofas
                    i like the dark style but think its maybe a little too much, maybe some more lites too add more life to the renders, but good job!! i like them πŸ‘
                    http://www.spazioarquitectura.com
                      BTM
                      BMW Z4
                      making a car in sketchup is one of those things I've always wanted to try, and this would be the first decent attempt I've had at it. Decently far into the model, still lacks a lot of details, and interior, but I'm posting it here none-the-less. πŸ˜‰
                      BMW.Z4.6.skp
                        BTM
                        Some in-SU pics of one of my latest models.
                        Everything but textures were made by me. If you're wondering why the turrets are so bad, the file size is huge, and I want to be able to upload it to the 3D warehouse, so i have to take away a LOT of detail 😞
                        (Images removed, different ones will most likely be re-posted.)
                          BTM
                          Sculpture! πŸ˜„
                          50748 faces, 77242 edges
                          β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
                          • soloS Offline
                            solo
                            Is this done with your under development sculpt tools?
                            Looking really good, if so, I cannot wait to get my hands on the final product.
                            http://www.solos-art.com
                              BTM
                              Yes, this was done with Sculpt Tools. πŸ˜‰
                              I've been fairly busy lately, and haven't gotten much more done on them, but I don't have too much more to do anyways. I mostly made this model just to see if I could, and to see what would make it easier to sculpt, as in visuals.
                                Sir
                                looks pretty awsome... do these compare to the 'sculpt' tools as integrated into modo?
                                  Mr S
                                  Here are your last renders after a bit of tweaking in Photoshop using levels and contrast adjustment. If these look too bright on your monitor you really need to make some adjustments or get a new monitor.
                                  Regards
                                  Mr S
                                    BTM
                                    'Clay' renders. Well, sorta. Going for a more realistic look than usually.
                                    • 2 / 2
