    Overly dark renders, and etcetera
    36 Posts 13 Posters 5.5k Views 13 Watching
      sojourner
      Hi BTM,
      From what I can see, those look great, but damn, I have my LCD set to max brightness and most of your images are still too dark to see. 😐
        remus
        Another vote for turning down your monitors brightness, no point hiding those beautiful models behind a veil of darkness πŸ˜‰
        • X Offline
          xrok1
          nice model! and a lot better lighting.
            BTM
            Renders of speed-modeling entry:
            ... Probably too dark again. I've gotta turn down my monitor's brightness for renders or something.
            Also: How is this thread still only on one page? Look at the scroll bar! πŸ˜†
            Here's a less dark render. Any better/worse?
              BTM
              I tried to make a non-dark render. Any better/worse? (also updated last post to tell difference)
              OLD...
              NEW...
              • O Offline
                oalexis
                i concur much better lighting on the second one πŸ˜„
                • tinanneT Offline
                  tinanne
                  Oh wow, much better! The second one looks great!
                  Executive Director : American Society of Architectural Illustrators
                  AIP 30 Competition opens soon. ASAI.org
                  Architectural Rendering
                  • FrederikF Offline
                    Frederik
                    I sure hope you don't mind...
                    Just took your first render through a quick tonemapping adjustment in Adobe Lightroom...
                    Not sure if your screen is adjusted to some games or alike, but they seem really dark...
                    Next time you render, you should try and increase the exposure settings a bit... πŸ˜‰
                    Cheers
                    Kim Frederik
                      BTM
                      Thanks for the advice πŸ‘
                      I was going for a bit of a nighttime look in the first 2 renders, and although they aren't too dark for me, I did intend them to be a bit dark. My 3rd one looks more like someone just turned the lights on.
                      Frederick: πŸ‘ . Also, how do I use volume lighting to create god's fingers without slowing my render down to 1% for 10 minutes?
                      (I use KT)
                      • boofredlayB Offline
                        boofredlay
                        Great renders.
                        However, let me quote a line from those pesky Competition rules πŸ˜„
                        -Sketchup output only (and as much as i know you love rendering your models, it would be appreciated if you could hold of posting them in the gallery until after the comp.)
                          BTM
                          Oh, I didn't notice that... but it's not in the comp section... so we can't even post them in the gallery?
                          • FrederikF Offline
                            Frederik
                            (I use KT)
                            Volume lightning and soft shadows is a bad mix... πŸ˜‰
                            Which also makes sence, since KT is a GI render application... πŸ˜‰
                            Only use one of them at a time... Never together... πŸ˜‰
                            click Settings > Scene...
                            You'll now see a window with 3 tabs... (Lights, Cameras and Global Settings)
                            Select the Global Settings tab...
                            In the Ambient & Volume Lightning field, you need to check that Volume Lightning is ticked...
                            In the Global Fog field you just need to adjust the Scatter settings... (you may start with .05 or .1)
                            You can find a small scene here, which you can use to play with... πŸ˜‰
                            Please note! ❗ Volume lightning will increase your render time significantly... 😐
                            If you don't like longer render times, you can make Gods Ray in post pro...
                            Cheers
                            Kim Frederik
                              boofredlay
                              Correct.
                                BTM
                                so...do I remove them untill after the comp???
                                  boofredlay
                                  That is up to remus.
                                    remus
                                    I think leave them in place this time. I'm too lazy to copy them all and put them back in after the comp πŸ˜‰
                                    Please dont do it again, though. If i'm in a bad mood theres a good chance i'll just delete the offending posts.
                                      teofas
                                      i like the dark style but think its maybe a little too much, maybe some more lites too add more life to the renders, but good job!! i like them πŸ‘
                                      http://www.spazioarquitectura.com
                                        BTM
                                        BMW Z4
                                        making a car in sketchup is one of those things I've always wanted to try, and this would be the first decent attempt I've had at it. Decently far into the model, still lacks a lot of details, and interior, but I'm posting it here none-the-less. πŸ˜‰
                                        BMW.Z4.6.skp
                                          BTM
                                          Some in-SU pics of one of my latest models.
                                          Everything but textures were made by me. If you're wondering why the turrets are so bad, the file size is huge, and I want to be able to upload it to the 3D warehouse, so i have to take away a LOT of detail 😞
                                          (Images removed, different ones will most likely be re-posted.)
                                            BTM
                                            Sculpture! πŸ˜„
                                            50748 faces, 77242 edges
                                            β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
                                            • 2 / 2
