    Proble with texture
    9 Posts 4 Posters 773 Views 4 Watching
      christouille
      Hello.
      I a'm a newbie with Sketchup. Iam french but I wasn't be able to register me in the french forum.
      I have a big problem to put the texture in my draw.
      Each time i choose a texture, this one is completely distord.
      I wan't to add a logo on my presentation and texture took only the color and a very big image completely not right.
      For all the texture is the same. When I choose stone, it's only grey on my sketch.
      Could you help me?
      Best regards,
      Chrstouille
      • V Offline
        Voder Vocoder
        Christouille,
        Can you upload a model exhibiting these problems?
        ~Voder
        • Jean-FrancoJ Offline
          Jean-Franco
          Christouille,
          to join the french forum you have to clic on User Control Panel (UCP) then select "Usergroup" and tick the group you want to join.
          Ensuite on pourra se parler en français si tu préfères 😄
          Jean-Franco
            christouille
            Thank you very much for your help for french forum.
            I put you 2 pictures:
            1 with the selected texture, the second one with the result on outside wall.
            I precize that I have the same results for others textures.
            I have too if i import my own picture in texture.
            Thank yo ufor your attention.
            http://img266.imageshack.us/img266/5117/20081130215102jv8.th.jpg
            http://img88.imageshack.us/img88/835/20081130215232pv0.th.jpg
              christouille
              I give you another sample of lmy problem :
              http://img293.imageshack.us/img293/4893/20081130223756uv1.th.jpg
                Jean-Franco
                IMO and looking at your first picture, the problem is not related to the texture but to your drawing.
                The wall seems very strange to me. Could you post your skp file. It will be easier to fix the problem.
                Jean-Franco
                  Jean-Franco
                  PROBLEM HAS BEEN SOLVED >>> in the french forum.
                  Jean-Franco
                    Hi Jean-Franco,
                    Could you still tell us what the problem was? Just for the sake of the non French...
                    Thanks.
                      Jean-Franco
                      Hi Gaieus,
                      sorry not having expplained the problem.
                      In fact as very often it was related to the hardware acceleration. After disabling it all was OK.
                      Graphic card was ATI radeon hd 2600 and under Vista.
                      Jean-Franco
