    Simple question
    5 Posts 4 Posters 1.9k Views 4 Watching
    • J
      Jorgensen
      Would it bee easy to covert an existing component to DC ?
      I have a café table, and would like the option to select if the table is emtpy or if it contains plates 😄
      It would be a nice way to fill a café
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • GaieusG
        Hi Bo,
        Actually it should be easy - I mean no "harder" than from scratch since you should start with "simple" components anyway and add attributes to them during the "turning" (to DC) process.
        I think a hide/unhide command (if that is posible with DC's) could do this trick.
        • thomthomT
          That would be very easy to do. You'd add a custom attribute to your Table component, say "Empty", and allwo the user to choose between Yes or No. Then you link the Hidden attribute of your component containing the plates to the "Empty" attribute.
          • C
            cosycat
            Attached is a basic file made up from items from the warehouse.
            If you use interact tool you can switch between and empty and full table
            To see how it works, go to Component Attributes and switch on formula view- notice how the custom variable 'empty' is referenced in the 'items' attributes i.e. table!empty
            Essentially it is as thomthom has described
            table.skp
            • J
              Jorgensen
              Wow that was simple 😄
              Thanks.
