    Possible to import DC attribute values?
    7 Posts 4 Posters 9.6k Views 4 Watching
    • M
      marksolberg
      If I have a DC with a custom identifier attribute like ProductNum is it possible to import and set a different attribute, say LenZ based upon an external file? Basically I would like to use Sketchup to visualize performance data. An example file might be something like:
      A34 3.5
      B22 9
      B33 7
      Perhaps with a custom Ruby script?
      Thanks,
      Mark
      • chrisglasierC
        chrisglasier
        @marksolberg said:
        ... Basically I would like to use Sketchup to visualize performance data.
        Anything useful here:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14299 ?
        or on my web site (click button on left). I am interested in the versatility of import/export with webdialogs, so please let me know what you think.
        Chris
        edit: corrected link
        With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
        • chrisglasierC
          chrisglasier
          Correct link is this:
          Sorry
          Chris
          • M
            marksolberg
            Chris,
            I couldn't get the video to play in the linked topic. I don't know that it would matter though. I think this is beyond my knowledge. I didn't make it past the first paragraph before I got that look a dog gets when they hear an unfamiliar sound. Thanks just the same.
            Mark
            • J
              Jim
              A34 3.5
              B22 9
              B33 7
              Thanks,
              Mark
              Welcome Mark,
              It is possible, and actually not terribly hard to write a Ruby script to set some attributes from a file. It's a little late for me, but perhaps someone will pick this up in the morning.
              Also, Scott Lininger has posted some good information on the subject, which I will quote here:
              Hey folks,
              My name is Scott, and I'm one of the developers for DCs. I'll be
              floating around the groups from now on to help with all things Ruby or
              DC related. Hiya! First, let me say that we intend to provide more
              docs and examples of using your own Ruby scripts alongside DCs, but
              they are still under development, so I'll attempt to address specific
              questions as they come up.
              bveina has figured it out most of the way: DCs are implemented purely
              in Ruby, and all of the attributes that you can apply via the
              Component Attributes window can also be applied directly with script.
              There is a dictionary called "dynamic_attributes" that gets attached
              to both the Instance and the Definition, and this contains the
              attributes that drive DC behaviors.
              There are two kinds of attributes in these dictionaries: those that
              start with an underscore are "internal" attributes that do not show up
              in the Component Attributes window. Those that begin with anything
              else are the "visible" attributes. Here's an example of some
              attributes one might find in our dictionary (http://code.google.com/p/
              sketchupattributemanager/wiki/Welcome is a place where one can get a
              tool to view these attributes, and inspecting existing DCs is the best
              way to start to understand how everything is stored.)
              x=55
              _x_formula="5*11"
              _x_label="x"
              As bveina's script shows, there's nothing particularly secret or
              magical about setting these attributes. But how does one fire a
              redraw? First, there is an instance of the dc observers mechanism,
              which lives in this global variable:
              $dc_observers
              This object is, as its name suggests, essentially a collection of
              observers that watches for DC interactions, such as the scale tool,
              move tool, or component placement. Anyway, here's a code snippet that
              applies a color to Sang then redraws him (this assumes it's running in
              a template with Sang already in it):
              sang_instance = Sketchup.active_model.entities[0]
              sang_definition = sang_instance.definition
              ad = sang_definition.attribute_dictionary "dynamic_attributes"
              ad["_material_formula"] = '"Red"'
              $dc_observers.get_latest_class.redraw_with_undo(sang_instance)
              The only reason that we have to set the "_material_formula" instead of
              just the "material" is because Sang happens to contain formula
              already, so just replacing the material and then firing a redraw will
              result in the old formula overwriting your new value. (Formulas always
              get recalculated with a redraw, and their result is stored into the
              attribute.)
              Whew! How's that for a 10-minute intro. πŸ˜‰
              As I say, all of this will be better documented soon, but that's no
              reason to keep you from diving in! DCs are "just another Ruby script,"
              after all.
              Cheers,
              Scott Lininger
              Sketchup Software Engineer
              (source)
              • M
                marksolberg
                Thanks Chris,
                The info in your last post seems to be the type of info I'm looking for. I'll post this in a separate forum also, but do you have any recommendations as to where to start learning Ruby programming for Sketchup? About a hundred years ago I went to college for programming (pre-WWW days) but somehow ended up in the casino industry in a non-programming capacity. Wish I would have stayed with programming, I've always enjoyed it.
                Mark
                • W
                  Witention Newcomers
                  @marksolberg said:
                  Thanks Chris,
                  Mark
                  Good day. I have always liked the field of programming, I reported a lot of efforts to become a programmer, now I am programming in C ++. As for the casino theme, I like this business, I like to hang out in my free time https://forestcasinos.co.nz/casino-zodiac/. It helps me recover and relax from a hard day's work.
