    Need help with textures please!
    6 Posts 2 Posters 686 Views 2 Watching
    • S
      SixtiiSvn
      Hi everyone!
      I am new to sketchup, but i already have the basic knowledge. In 3D Warehouse there are textured that you can download. All i get is a sketchup file with a 3d block with squares on it. I know those each of thoses squares is a texture but how to i use it is my question. I need to export it into my other file, that would help to!
      Thank You for your help who ever helps!
      Hard to think of what to put here, so I put this.
      • GaieusG
        Hi SixtiiSvn,
        They probably come in as groups or components. You can double click and edit them (or right click > explode if you don't want them grouped).
        • S
          SixtiiSvn
          Thank You!
          But how do i save them so i can use then later in my textures. For example when i look thought my materials i want my textures to appear there, or is this simply impossible?
          • GaieusG
            When you open the Material browser, go to "In model" and next to the dropdown list you can see a little, blue,arrow shaped button. If you press it, a menu appears where you can choose "save library as" and save it out for later use.
            When you already have a library, you can open a secondary window (the + button in the top right corner) where you can open your folders (libraries) into which you can simply drag and drop your materials from above.
            • S
              SixtiiSvn
              Thank You! That helped! This site is good, i get replies right away!
              • GaieusG
                πŸ˜‰
