    Need help with textures please!
    6 Posts 2 Posters 434 Views 2 Watching
      SixtiiSvn
      Hi everyone!
      I am new to sketchup, but i already have the basic knowledge. In 3D Warehouse there are textured that you can download. All i get is a sketchup file with a 3d block with squares on it. I know those each of thoses squares is a texture but how to i use it is my question. I need to export it into my other file, that would help to!
      Thank You for your help who ever helps!
      Hard to think of what to put here, so I put this.
        Hi SixtiiSvn,
        They probably come in as groups or components. You can double click and edit them (or right click > explode if you don't want them grouped).
          SixtiiSvn
          Thank You!
          But how do i save them so i can use then later in my textures. For example when i look thought my materials i want my textures to appear there, or is this simply impossible?
            When you open the Material browser, go to "In model" and next to the dropdown list you can see a little, blue,arrow shaped button. If you press it, a menu appears where you can choose "save library as" and save it out for later use.
            When you already have a library, you can open a secondary window (the + button in the top right corner) where you can open your folders (libraries) into which you can simply drag and drop your materials from above.
              SixtiiSvn
              Thank You! That helped! This site is good, i get replies right away!
                ๐Ÿ˜‰
