    Vue 7 Infinite
    extensions
    77 Posts 17 Posters 18.3k Views 17 Watching
      Sheik
      Well it looks like Vue7 is out. Has anyone tested it yet?
      I have always hated Vue for the lack of realworld units, but it is now said to work.
      Can I now really import my SKP file, so that it is ín "real scale" in Vue, and I can then place plants that are properly scaled to go with the model, and even the environments work in scale (like fog doesn't become too strong)?
      How well is the SKP import now working? Does it come in with textures ok? Are softened edges soft or faceted? Does a SKP files still import as one object?
      Sheik
      • soloS Offline
        solo
        Trust me Vue 7 is awesome.
        Check out this video, everything is done in Vue 7 inf.
        http://www.e-onsoftware.com/products/vue/vue_7_infinite/v7i_video_layout.php
        http://www.solos-art.com
          Sheik
          The vid looks great.
          How about the improvemts in workflow from SU to Vue? I wasn't too happy with that in Vue6. Can I now make a model in SU, like an large scale urban plan, and then (comfortably) populate it with ecosystems etc.?
          On the video the render quality looks better than it was in Vue6, is it?
          • soloS Offline
            solo
            Yes you can, even with 6 it was possible (see my site for examples)
              Mr S
              Hi Pete,
              Just come across this post and visited your site.
              You have created some beautiful images there.
              Also visited the Vue 7 site you provided a link to.
              WOW! That looks like Hollywood quality standard.
              You seem to have used a variety of rendering software.
              I noticed that Vue seems to be able to produce a wonderful atmospheric look to the finished images.
              Some of them seem to have a dreamy hazy look which I haven't seen elsewhere.
              They look really nice, I will have to try it out.
              I see you use 3DS MAX and SU Podium as well.
              I have a couple of questions for you...
              What makes you choose a particular rendering solution for each individual project?
              How long did it take you to import your SketchUp files and create your Vue scenes?
              How long did your Vue renders take to complete?
              Which rendering solution do you find the "easiest" to use?
              I assume SU Podium would be your choice when fast results (compared to MAX or Vue) are required?
              Which package handles native SketchUp files (not including SU Podium) best?
              If you don't import native SketchUp files, which file format do you choose to export as, 3DS, OBJ, FBX etc?
              Do you have experience of using Vray or Modo?
              I don't know about yourself, but there doesn't seem to be enough hours in the day to earn a living, eat, drink, sleep and spend at least some time with your family.
              For this reason I don't want to avoid spending weeks or months studying how to use a program that I end up never really using.
              I would really appreciate hearing your views.
              Regards
              Mr S
              • soloS Offline
                solo
                Yup, I use a few other apps too like Z-brush, C4D, Hexagon, Maya, Shade, Bryce, Silo, (learning Modo), etc.
                It really depends on what the client needs and the time of the project, I usually use Podium for interiors and quick turn around work, Max for very detailed studio work, Vue for exteriors, Maya for characters, Hexagon and Z-brush for very complexed organic models, C4D for product animation, etc.
                Import is almost instant, faster than opening the model in SU actually. As for setting up the scene, that's another whole process of adjusting and tweaking textures, adding ecosystems, adding solid growth trees, playing around with your atmosphere editor for the best lighting, shadows and general atmosphere. Sometimes one nails it on the first go and other times one has to fiddle around to get the image in your mind to reflect on screen.
                Depending on the detail, render options, size, atmospheres, texture qualities (list goes on) I have learned many work arounds to optimize a rendering. I do not have the patience to wait more than an hour for a medium quality render (none of my Vue renderers on my site too longer than an hour)
                Podium for sure, with some awesome results too.
                Definately my favourite app, however it does not support atmospheres and due to the fact that it works within SU it is limitted to the low poly issue and vegitation I require is not possible, hence Vue is used.
                Here is a heads up on Vue 7, there is no need to spend $900 on the Inf package as the $600 Vue7 Complete has everything you will need, including .skp import.
                I always used .3ds, I have never had an issue.
                Learning Modo at moment (strange GUI to master), I have never used Vray (too expensive for my budget)
                There isn't, thus one needs to move computer to lounge/dinning area, get very comfortable chair (for sleeping in) and a side table for eating purposes (a mini refrigerator is an added advantage), Full size cut-outs of yourself placed in strategic parts of the house may work on the family issue.
                It's a tough call, why not try the demo and if you feel you can get into it then it's a go, if you get irritated and it seems a labor and not a love...walk away as you will only be wasting time and money.
                I wanted to test out a material, if anyone has Vue could you test this texture on your side. The image below is the texture (glass and metal for a distant city)
                and attached is the .mat, Unzip it and save .mat in a folder.
                http://img366.imageshack.us/img366/663/glassandmetalsoloca1.png
                glass and metal.zip
                • soloS Offline
                  solo
                  Another test material...
                  Rust and paint.
                  http://img266.imageshack.us/img266/7052/rustandpaintvz0.png
                  rust and paint.zip
                  • soloS Offline
                    solo
                    Cracked asphalt...
                    http://img411.imageshack.us/img411/1149/crackedasphalteu7.png
                    cracked asphalt.zip
                      sliner
                      To Solo
                      Has looked your gallery, very great and qualitative renders! About Vue it is clear, but how you have inserted plants into a Podium?
                      http://fancyquest.ru/albums/yucca/
                      • soloS Offline
                        solo
                        Sliner,
                        Thanks.
                        I used clipmaps for my vegetation in Podium, however with the new version 1.6 available it now works with .png's which is my easier to use.
                          sliner
                          I too have done many png-plants, but my Podium 1.5 did not see a transparency and I have removed it, Kerkytheya too for the same reason. Has tried to plant trees and shrubs in Vue, there except the vegetation magnificent, also it is possible to insert my alpha planes, and in general it is beautiful very much, only it is a little long...
                          • soloS Offline
                            solo
                            In Vue it's very easy to use alpha images, just select an alpha plane and in dialogue box navigate to the .png image and viola!
                            Have you tried the new Podium 1.6 yet? as it's much faster and it supports .png's very well.
                              sliner
                              I have already tried to make in Vue alpha planes, really easily, thanks, only a question: it is possible to use very much them, like instanses? Though I only have started Vue to study and mine question probably the foolish? In the same place it is possible to do or modify excellent plants also...
                              And Podium 1,6 I will look necessarily, and once again I will test on exteriors
                              • soloS Offline
                                solo
                                Yes it's possible to mass your alpha plane vegetation, make one and save it as an object in a folder within your objects library. Then in spray ecosystem or material ecosystem (your choice) you select 'object' and navigate to the saved object, then spray away.
                                As for modifying the solid growth plants and trees, just right click on it and select edit, you can modify everything from the trunk, branches and leaves, from sizes, lengths, girth, gnarly, twist, curl, etc.
                                  sliner
                                  Thanks big, Solo! When I will try, I can show that has turned out with alpha planes and native Vue plants. It is a pity they are just similar either on wild, or on Martian, and at me work such that recognition of garden plants is important...
                                    linea
                                    Pete thanks for explianing your workflow and preferences. I had a very early version of Vue, I think it was the only render app that I ever got near to really understanding. I didn't like it for modelling though, but I was always happy with the renders. I think you have convinced me to invest in Vue 7.
                                      Mr S
                                      Hi Pete,
                                      Thanks for taking the time to answer all my questions.
                                      Lots of useful points to think about there.
                                      I liked this the best:
                                      Maybe if they could speed up the human cloning project that may help? 😄
                                      Regards
                                      Mr S
                                        sliner
                                        @solo said:
                                        ...Have you tried the new Podium 1.6 yet? as it's much faster and it supports .png's very well.
                                        Today has tried Podium, with vegetation all is excellent, the transparency in tiff and png understands, its plant models the truth a bit left unfinished, not cut off and axes not on the centre.
                                        But all any blue at rendering also were gone somewhere options of shades...
                                          Bruell
                                          Warning,!!!!!!!!!!!!!!!!!!
                                          do NOT buy VUE 7I yet, It is a great render software but the current version has major bugs, so if your life depends on this,
                                          don't buy yet, wait for the first patch/update.
                                          • StinkieS Offline
                                            Stinkie
                                            We got it by now. 😆
                                            • 1 / 4
