    Vue 7 Infinite
    extensions
    77 Posts 17 Posters 18.4k Views 17 Watching
    • soloS Offline
      Another test material...
      Rust and paint.
      http://img266.imageshack.us/img266/7052/rustandpaintvz0.png
      rust and paint.zip
      • soloS Offline
        Cracked asphalt...
        http://img411.imageshack.us/img411/1149/crackedasphalteu7.png
        cracked asphalt.zip
          sliner
          To Solo
          Has looked your gallery, very great and qualitative renders! About Vue it is clear, but how you have inserted plants into a Podium?
          http://fancyquest.ru/albums/yucca/
          • soloS Offline
            Sliner,
            Thanks.
            I used clipmaps for my vegetation in Podium, however with the new version 1.6 available it now works with .png's which is my easier to use.
              sliner
              I too have done many png-plants, but my Podium 1.5 did not see a transparency and I have removed it, Kerkytheya too for the same reason. Has tried to plant trees and shrubs in Vue, there except the vegetation magnificent, also it is possible to insert my alpha planes, and in general it is beautiful very much, only it is a little long...
              • soloS Offline
                In Vue it's very easy to use alpha images, just select an alpha plane and in dialogue box navigate to the .png image and viola!
                Have you tried the new Podium 1.6 yet? as it's much faster and it supports .png's very well.
                  sliner
                  I have already tried to make in Vue alpha planes, really easily, thanks, only a question: it is possible to use very much them, like instanses? Though I only have started Vue to study and mine question probably the foolish? In the same place it is possible to do or modify excellent plants also...
                  And Podium 1,6 I will look necessarily, and once again I will test on exteriors
                  • soloS Offline
                    Yes it's possible to mass your alpha plane vegetation, make one and save it as an object in a folder within your objects library. Then in spray ecosystem or material ecosystem (your choice) you select 'object' and navigate to the saved object, then spray away.
                    As for modifying the solid growth plants and trees, just right click on it and select edit, you can modify everything from the trunk, branches and leaves, from sizes, lengths, girth, gnarly, twist, curl, etc.
                      sliner
                      Thanks big, Solo! When I will try, I can show that has turned out with alpha planes and native Vue plants. It is a pity they are just similar either on wild, or on Martian, and at me work such that recognition of garden plants is important...
                        linea
                        Pete thanks for explianing your workflow and preferences. I had a very early version of Vue, I think it was the only render app that I ever got near to really understanding. I didn't like it for modelling though, but I was always happy with the renders. I think you have convinced me to invest in Vue 7.
                          Mr S
                          Hi Pete,
                          Thanks for taking the time to answer all my questions.
                          Lots of useful points to think about there.
                          I liked this the best:
                          I don't know about yourself, but there doesn't seem to be enough hours in the day to earn a living, eat, drink, sleep and spend at least some time with your family.
                          There isn't, thus one needs to move computer to lounge/dinning area, get very comfortable chair (for sleeping in) and a side table for eating purposes (a mini refrigerator is an added advantage), Full size cut-outs of yourself placed in strategic parts of the house may work on the family issue.
                          Maybe if they could speed up the human cloning project that may help? 😄
                          Regards
                          Mr S
                            sliner
                            @solo said:
                            ...Have you tried the new Podium 1.6 yet? as it's much faster and it supports .png's very well.
                            Today has tried Podium, with vegetation all is excellent, the transparency in tiff and png understands, its plant models the truth a bit left unfinished, not cut off and axes not on the centre.
                            But all any blue at rendering also were gone somewhere options of shades...
                              Bruell
                              Warning,!!!!!!!!!!!!!!!!!!
                              do NOT buy VUE 7I yet, It is a great render software but the current version has major bugs, so if your life depends on this,
                              don't buy yet, wait for the first patch/update.
                              • StinkieS Offline
                                Stinkie
                                We got it by now. 😆
                                • soloS Offline
                                  Bruell, sorry to hear about your issue, my business relies on my software and I made the jump to version 7 without any issue.
                                  Anyway moving on....
                                  Did you know Vue has amazing animation tools?
                                  Here are two quick samples.
                                  This on I did (crude 5 minute animation render) of a ball rolling.
                                  [flash=600,400:eura63dd]http://vimeo.com/moogaloop.swf?clip_id=2324780&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:eura63dd]
                                  This one was done by Vovka from geekatplay.com showing Vue's ability to handle D.O.F.
                                  301 Moved Permanently
                                  (www.vimeo.com)
                                  [flash=600,400:eura63dd]http://vimeo.com/moogaloop.swf?clip_id=2324810&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:eura63dd]
                                    Kenny
                                    Solo, Before we lost the last few days posts due to the server crash, there was a discussion on Vue distorting and 'scattering' faces of some imported models. Attached is a screenshot of an example. Also here is a link to the skp file.
                                    http://www.mediafire.com/file/x2jtzonwgzj/Vue fragmented.skp
                                    Not only are the faces fragmented but the plan view has 'scattered' various parts of it around the site. I'd like to know if Vue 7 Infinite is better in this respect. I only have Vue 6 PLE that I'm testing at the moment. My aim is to create a Sketchup site model minus the vegetation and then insert the landscaping in Vue. Any thoughts would be appreciated.
                                    Kenny
                                    http://www.townscapesolutions.co.uk/
                                      Charlie__V
                                      Kenny,
                                      In VUE I6...File...options....display options....3d view display options:
                                      Try enableing background draw thread and increase the sliders for instant draw and backgound draw.
                                      This should correct the missing faces you are experienceing.
                                      THEORY:
                                      As for the scattering in VUE I6 I believe the scattering happens when components that have nested components/groups are imported to Vue and Vue has trouble with this.
                                      Try importing a problematic model without nested components to test this theory.
                                      Best,
                                      C
                                      • soloS Offline
                                        Kenny,
                                        No problem at all with Vue 7 I tried direct importing the .skp and I also tried by exporting .3ds from SU and importing into Vue without any scattering or issues.
                                        nb I purged your model of 54 styles 😮
                                        http://img91.imageshack.us/img91/1966/kennycw5.jpg
                                        • soloS Offline
                                          Vue 7 also has improved radisosity and speed, this indoor image took 11 minutes to render with medium settings.
                                          http://img385.imageshack.us/img385/1201/interiortes1t7uu9.jpg
                                          This one took 13 minutes using basic broadcast settings with volumetric light with dust particles enabled, I forgot to set the AA on this one.
                                          http://img147.imageshack.us/img147/8435/bed27bk7.jpg
                                          • soloS Offline
                                            Bruell
                                            Can you send me the model in .skp or .vue and let me see if the problem exists on my side, if not then I can send it back to you ready for you to carry on working.
                                            • 1 / 4
