    One material two different scales
    5 Posts 3 Posters 882 Views 3 Watching
    • A
      amo
      I have a material that is used on multiple planes; in one group the material is the normal scale and in another group the material is scaled only in one direction. If someone knows what the problem is let me know, I don't want to recreate the model again.
      • GaieusG
        Probably one of the goups (or the face inside the group) was scaled in that direction. Unfortunately there is no way to prevent materials from getting scaled with scaled geometry - even if you apply them after scaling.
        • Chris FullmerC
          You can right click on the group that is scaled wrong and choose "Make Unique" This will make it a new component. Then right click on it and choose "Scale Definition". That will then re-apply the material to it at the correct scale. Hope that helps,
          Chris
          All my Plugins I've written
          • A
            amo
            Thanks that corrected the problem.
            • GaieusG
              Yes, that's definitely a solution however not very "economic" with component instances.
