    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 71.1k Views 27 Watching
    • T
      teofas
      thx for your quick answer sepo, i apreciated bro!
      http://www.spazioarquitectura.com
      • J
        Jackson
        Not a stupid question at all, but believe me- once you start using ruby scripts with SU, you won't be able to stop as they can increase SU's functionality many many times over.
        Just save the .rb file to the "Plugins" folder in your Google SketchUp program files. The next time you open SU it will be accessible under the "Plugins" menu under the name "Remove C-G Materials".
        Jackson
        • free agentF
          free agent
          hi on the front page Mat666 says the new version has all the suggested improvements any way someone could post a features list, to save people (me) having to read through all 5 pages and descern what exactly was implemented ๐Ÿ˜„...
          lazy freeloaders...
          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          • M
            Matt666
            Sorry, I have no time to work on this plugin... ๐Ÿ˜ณ ๐Ÿ˜ž
            And components & groups easily generates lots of bugsplats... It's very hard to work with...
            Give me some time, I will certainly have a moment to improve it...
            Frenglish at its best !
            My scripts
            • P
              Pout
              is there an opposite of this plugin?
              one that just keeps the group/component materials but deletes the geometry materials inside it?
              regards
              • thomthomT
                regards
                It does now: http://forums.sketchucation.com/viewtopic.php?f=180&t=17587
                • EarthMoverE
                  EarthMover
                  Anyone notice a REAL dramatic difference in parsing after running this script? Whenever I have a really long parse, I'll run this script, but it never really seems to speed things up. Is it just me?
                  Content Creator at Skapeup
                  • thomthomT
                    Yes, there's a VERY big increase in parsing time.
                    At the end of the script it tells you how much was replaced - what does it tell you? It could be that you are running into other issues. Lots and lots of groups and component definitions eats time as well, more if they are deeply nested.
                    But groups/component materials eats the most of the time.
                    The reason it's so slow is that when VfSU runs into group/component materials it has to internally create a new copy of that object and in order to get the proper UV mapping it has to apply all the group/component material to the faces contained inside - then afterwards restore it. And that takes an insane amount of time.
                    • thomthomT
                      FYI: I have an imported Revit model that has 777 component definitions and ~2500 component instances. Totalling of about 70-80000 faces. This model takes 1-2 minutes to parse before it opens the render window and begin rendering.
                      And this model has no material at all - just plain default. If I had group/component materials applied the computer would tie a bucket of brick around itself and jump of the bridge...
                      • EarthMoverE
                        EarthMover
                        Must be other issues. It's really frustrating that there is no parsing progress bar. Or, the ability to have it only have to parse once. Seems like since it is just storing UV data, that as long as you don't move the camera, you should be able to reuse the same data. Nothing is more frustrating than having to wait for every test render.
                        On another note, I tried to open SS's Snowberry model (which took about 5 minutes to open) and render with VfSU (with no materials)......after 30 minutes of parsing, i just gave up.
                        • thomthomT
                          But you need to parse the whole lot again anyway to check if anything has changed.
                          The next version should see some improvements though.
                          That model is up in the millions in face count isn't it?
                          • M
                            Matt666
                            Hi all.
                            Sorry for the delay, I will see what I can do.
                            My scripts
                            • M
                              m48
                              holy shit, it really works!!! ๐Ÿ˜ฎ you s-a-v-e my a-s-s.
                              I need to give something in return men, i owe you one,you are my new hero.
                              • C
                                chango70
                                Do you still need to do this with the new Vray? (v1.488) I seem to encouter problems when with Vray 1.488 after running this script (not 100% this was the culprit)
                                Cheers
                                • thomthomT
                                  No - Only with 1.05.30 and older. The new one might actually be faster if you use group/component materials.
                                  • D
                                    dragonbizcut
                                    I can not run the remove CG materials plugin, is the link broken or corrupted?
                                    • thomthomT
                                      You have problem downloading or using the plugin?
                                      • C
                                        chango70
                                        Hey cheers, thats why...
                                        • A
                                          AliMG
                                          Thank-you Matt, Your plugin has saved me!
                                          • L
                                            lukdoberder
                                            nice plugin!definitely speed things up!thanks matt!
                                            • 4 / 5
