    3d warehouse error message
    5 Posts 3 Posters 879 Views 3 Watching
      Brooklyn
      Every time that I open sketchup 6 (pro), I get this error message...
      3D Warehouse (warehouserubyextension.dll): could not load object from 3DWarehouseClient.dll (probably was not registered)
      I click OK, and SU opens, and I'm able to go to the warehouse. Still, I'd rather not see that message every time.
      What can I do to fix this irritation.
      Steve
        Hi Steve,
        Do you have any WareHouse related plugin?
        • TaffGochT Offline
          TaffGoch
          Steve,
          Did you recently upgrade from SU5 to SU6?
          That '.dll' sounds like a 'carry over' from SketchUp 5. If you copy certain ruby files from a previous installation, to a new version-6 installation, you can cause problems when SketchUp gets to the plugin-initialization phase of starting up.
          The best prevention is to NOT copy ALL the '.rb' files from a SU5 folder to a SU6 folder, but to install the plugins one-at-a-time. You may be able to fix your current set of plugins, by referring to this discussion from May of this year:
          SketchUp Pro Help Group
          Taff
          "Information is not knowledge." -- Albert Einstein
            Brooklyn
            Gaieus,
            I have these files in my plugins folder...Enable3DWarehouse.rb
            and WarehouseRubyExtension.dll. The error message showed up when I
            got my new computer. Didn't see it before.
            thanks
            steve
              Brooklyn
              Taff,
              I moved the ruby file out of the plugins folder, and I don't get the error message anymore...and the warehouse still works.
              thanks
              steve
