    Church remodel...
    23 Posts 9 Posters 1.5k Views 9 Watching
      bubbalove
      I am including this picture to give everyone an idea of what's happenin...
      Before
      http://img397.imageshack.us/img397/9529/092608091id1.jpg
      By bubbalove, shot with KODAK Z730 ZOOM DIGITAL CAMERA at 2008-10-21
      After
      http://img397.imageshack.us/img397/4989/fadededgesmallwa8.jpg
      By bubbalove at 2008-10-21
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • marked001M Offline
        marked001
        nice simple image... new pews? (is that how you spell 'pew'?)
        http://www.revision21vis.com
        instagram: revi21on
          bubbalove
          No same pews... they're just going to be refinished...
            daarboven
            if this is "find the difference" i'd guess the altar was altered....nice clean style,btw.
              bubbalove
              Thanks daarboven, they're are a ton of styles floating around on this site as well as FormFonts...
                johnsenior1973
                If I was on the spending committee of the church I'd be voting to save the money and leave things as they are, rather than remodeling. If you did a Sketchup model of the church as it is now, there would be practically no difference between that and the remodel picture.
                You list the camera, is that a disclaimer for not being able to get the picture in focus?
                Good Sketchup work and style though.
                • StinkieS Offline
                  Stinkie
                  Nice work. Got a render as well?
                  You should add a disclaimer to your posts. "Contains vitriol."
                    bubbalove
                    John, the company I'm doing this for took all the pictures and imageshack imported the camera info when I uploaded.
                    Stinkie, I'll probably do one shortly so I will post when it is finished...
                    Durant, I don't know what will happen with the doors... I know I can't use them as I live in a apartment...
                      Durant Hapke
                      Big Bag BubbaLove,
                      That's a lot of clean you have, bring that.
                      I would take home the old doors when they pull them, and put them up in your crash crib.
                      Little widows are Jack bird cool.
                      I dig that action.
                      Killer.
                      I like the word "Vitriol" -- like acid baby -- not sure I found such in J1973's action response...
                      The universe of Churches, and Church goers is a bit of a wild deal -- supernatural as normal.
                      Getting some groovy changes is fun -- even if small -- if you are into it.
                      I'm sure paint will be involved, so it might look cleaner, but I feel the vibe of "do it."
                      Free your mind and Jack bird couple up with the universe.
                      Durant "wires go both in and out" Hapke
                        bubbalove
                        Here is the render... I still need to work on a few things such as the carpet, ceiling, and wall paint! Everything seems to want to turn red because of the carpet and pews and I can't quite get my head around that yet! This is also the first time using IES lights and they definitely look better than the normal spot or pointlights from Kerkythea! Now I just have to try and find more...
                        http://img371.imageshack.us/img371/8179/kerkyrendersmallcn8.jpg
                        By bubbalove at 2008-10-23
                        • DanielD Offline
                          Daniel
                          Nice looking rendering, David, although I agree the pink glow from the carpet aint too pretty (but then, I detest the color pink). I have one design crit: the casing around the 6-panel doors looks too thin, IMHO. What are the dark squares over said doors?
                          My avatar is an anachronism.
                          • soloS Offline
                            solo
                            David, if you change the carpet from a color to a texture it should remove the pink tint in render.
                            http://www.solos-art.com
                              bubbalove
                              They are supposed to be speaker screens but I messed up and made them too dark... they were supposed to be the color of the walls... whoooopsies! It's funny you say that about the door casing... as I made it extra thick so the chair rail would die right into to it... maybe its the perspective?
                                bubbalove
                                It is a texture Pete, I also added a bump map to it... I know it is definitely my material settings but I just don't know what to do... anyone with experience in Kerky maybe can help! I will post it in the Kerky boards as well and see if I can get something outta them...
                                • soloS Offline
                                  solo
                                  I am not versed in KT, but if there is a way of toning down the Irradiance then you may be able to overcome this.
                                  Or a quick color correction in PS should help for a quick fix.
                                  http://img293.imageshack.us/img293/1079/kerkyrendersmallcn8ed3.jpg
                                    bubbalove
                                    Ahh... alright, bout to give it a shot...
                                    • DanielD Offline
                                      Daniel
                                      David, I think the thickness of the casing is fine, but for traditional doors such as those the casing should be wider.
                                        bubbalove
                                        Ohhh... I'm trying to fix the 'pink' problem right now but I will fix that... client didn't catch that one...
                                          bubbalove
                                          Well here is the updated render... still got some 'pink' issues but it's not as bad... anyone?
                                          http://img133.imageshack.us/img133/6025/kerkyrender2xe2.jpg
                                          Pete, I'm not all that good with PS. I changed the hue/saturation for the ceiling on this one... is it any better?
                                          • soloS Offline
                                            solo
                                            Definately a lot better, I use paintshop pro (not a PS fanboy), I adjusted the back lighting and flashfill.
                                            http://img528.imageshack.us/img528/135/kerkyrender2xe2ou3.jpg
                                            • 1 / 2
