    Drape Bugsplat
    4 Posts 4 Posters 842 Views 4 Watching
      dylan
      I am asking if someone can just check the following file please.
      I have created a landscape with From Contours using an ACAD provided .dwg.
      I can import the contours, run From Contours and it creates the surface ok.
      Where I am having problems is in draping the road/building outlines onto this new surface.
      I constantly get a Bugsplat at 40%.
      Even if I draw a single line above the surface to Drape, it still Bugsplats at 40%.
      Can someone check the attached dwg on their machine please, just so I can eliminate the possibility of it being partly to do with my comp.
      2004 Format
      http://dmdarchitecture.co.uk/
        Hi Dylan,
        No problem here draping it (although it's a rather slow craputer in the office). I only draped a square however.
        Drape.skp
          alpro
          Seems to work fine for me also.
          Mike
          • Y Offline
            yahellid
            I am currently having the same problem. Suddenly, today out of nowhere, I get the bug splat everytime I try to drape something. Including draping one rectangle onto another.
            Your file crashed my Sketchup.
            I've been dealing with this this morning. I have uninstalled and reinstalled SU. Still have the problem.
            I have the most recent version. I do not understand what's causing the problem.
