    Contour lines on irregular surface
    15 Posts 7 Posters 1.5k Views 7 Watching
    • pbacotP Offline
      Does a ruby do this? Place topographic contour lines ? Perhaps it would be more correct if the lines (with coloring or not) were made with a texture, but I wonder if that's possible?
        remus
        Its fairly easy to do this by hand, if you want to.
        The easiest way is to just use a texture, side on to the terrain, which is just a graduated series of colours. You can then project it on to the terrain.
        • pbacotP Offline
          Thanks, I'll try that. I did the above with an array of planes and intersect.
          OK, I tried it. Yay SU!
          I expected to find a clean gradient on the web. As you can see I found a texture that wasn't tiled well and I got one with a rough pattern which adds to the streakiness. I could probably make one in PS that's much cleaner, but I don't have PS.
          • fredo6F Offline
            fredo6
            It could be done with a Ruby just using a series of horizontal planes to cut the topographic surface at given altitudes.
            This will allow to generate the contour lines, by constructing the intersections.
            then, you color each face of the topographic surface based on finding out for each face which horizontal planes it is in between.
            Certainly some good use of CPU, but nothing too complex in terms of coding.
            As an input, you would need
            • the topographic surface (as a selection of face or group or components)
            • a master plane (probably the horizontal plane), given by a normal vector
            • an origin and a pace to generate the series of planes
            • a color list (or scheme to change the color) along with the series of plane and pace
            Fredo
            • Didier BurD Offline
              Didier Bur
              I wrote several scripts to do that a while ago. Search for "contour" on my site and "paint altitude faces".
              Regards,
              DB
              • pbacotP Offline
                OK thanks a million!
                Here's one with lines in the texture. As you can see the result is not as nice as interstecting the shape with planes.topo 6.png
                This one is using intersect with planes but using a copy and overlaying the resulting lines so the earth form isn't affected.topo 7.png
                Now to see what Didier hath wrought.
                • pbacotP Offline
                  Fredo,
                  Just having done both methods, it seems to me that the texture would be better, so that you do not compromise the geometry of your shape. You could then revise the shape and have the topographic pattern adjust. The trick of a ruby would be a well dimensioned (in the case of contours), scaled, and standardized texture. Choices of contours and colors or both would be nice. Choice of scale, for lot-sized grading plans versus mountain-sized maps, would be good. The contour intervals and colors would be adjusted for each.
                  I began to think of this from a gallery house site render that used a simple colored ground with topographic contours. It was an effective way to finish the image without a lot of texture and entourage. Subtle color change would have been nice too (not rainbow colors as I show here).
                  Peter
                  • TaffGochT Offline
                    TaffGoch
                    Peter,
                    Sorry I didn't catch this discussion earlier. Any help here?
                    Terrain Tech - Google 3D Warehouse
                    Taff
                    "Information is not knowledge." -- Albert Einstein
                    • pbacotP Offline
                      @taffgoch said:
                      Peter,
                      Taff
                      Taff
                      Wow, beautiful looking models / demonstrations. Thanks for the post! How do you generate the terrain in the Palo Duro and Panther Creek models?
                      Peter
                      • pbacotP Offline
                        Didier,
                        I get this message:
                        Error Loading File contour_lines.rb
                        undefined method `file_loaded?' for main:Object
                        Peter
                          Matt666
                          You have to add this line in the Ruby file (if you have access..) :
                          require "sketchup.rb"
                          Frenglish at its best !
                          My scripts
                          • pbacotP Offline
                            Thanks. I did look at another file and searched for a likely header. I suspected this was part of it, from the little messing around I've done with simple files like DXF before. I'll try that.
                            Peter
                            • TIGT Online
                              I also wrote a contour script a while ago.
                              Remember to Group the terrain first...
                              ContourMaker.rb
                              • TaffGochT Offline
                                TaffGoch
                                @pbacot said:
                                How do you generate the terrain in the Palo Duro and Panther Creek models?"
                                Peter,
                                I download USGS DEM data files from the GIS Data Depot, to start.
                                SketchUp can import DEM files, but they're HUGE! I import them into TerraGen, and select the portion of the topographic map in which I'm interested, sub-sample (simply) the data, and export as a DXF file. These steps reduce the complexity of the mesh data, and produce a much more reasonably-sized data file for SketchUp to import. (TerraGen is free, as are a couple of plugins required to do the DXF stuff.)
                                Once you've done it a few times, it goes pretty quickly. (By the way, topographic map imagery can also be downloaded from the GIS Data Depot.)
                                Taff
                                • pbacotP Offline
                                  TIG,
                                  I tried yours and it seems to work great for what I was doing (rather than duplicating planes and intersecting "by hand"). Also gives the lines as a separate group, instead of making them part of the mesh, which I like.
                                  Taff,
                                  I think your ruby will do the same thing once I fix the header. I am not sure the paint faces ruby works for the effect I was looking for, as it does not give a graduated texture, nor colors by contour. It might be useful if the model is used in analysis. I only got one color, though I picked other ones. It has an interesting look, like an iceberg. Just for your info (not complaining) where you put in a number (default 10) is is not clear what the number is and that there is a limit, seems to be about 46). The lower numbers give a very subtle effect. If you go too hight the colors repeat, starting with the dark color.
                                  Your terrain models are very helpful (wish SU were faster in flying over).It would be neat to do the model of a place you are going to visit and hike in. And I like the effect you got with the lake surface.
                                  Thank you both for the help.
                                  Peter
