    [Plugin] Smoothstep Animation
    80 Posts 50 Posters 97.0k Views 50 Watching
    • romboutR Offline
      rombout
      @rickymon said:
      Hey guyz
      I know this is an old thread, but just for you to know...
      Was looking for a plugin to animate objects, and I found Properanimation.rb by morisdov
      This is a very cool plugin but did not have any way to export, native SU export engine did not support it. There are hughe threads about this issue, other people was considering to make screencapture videos, or get fancy external render engines.
      But guess what...?
      Smoothstep Animation not only exports smooth camera scenes, it also recognizes all Properanimation.rb animations.....!!!!
      So if you are looking for a cool tool to animate objects, try both plugins
      Properanimation.rb + SmoothstepAnim.rb
      Uploading utube
      http://www.youtube.com/watch?v=UL6tnTvphAE
      Done
      but how did you get to export all geometry, cause i thought he said i could only export images???
        rickymon
        @rombout said:
        @rickymon said:
        Hey guyz
        But guess what...?
        Uploading utube
        Done
        U can make a video out of a sequence of images, twhat I didnt knew is that both plugins were compatibles. So u dont need any fancy external engine to export smooth transitions and object animation. Unless u wanna go photorealistic. }
          Jakson
          I made as well some small change to the script, I hope you don't mind.
          Added support of saving the Export Property's to the Model.
          If you cancel the export dialog or the save dialog the script stops instantly.
          And reduced the filenumber padding to 6 numbers.
          And my first Animation with Properanimation + SmoothstepAnim http://www.youtube.com/watch?v=agCUtjEJssM
          smoothStepAnim.rb
          • dereiD Offline
            derei
            Is it a similar plugin to this one http://forums.sketchucation.com/viewtopic.php?f=323&t=33417 ?
            DESIGNER AND ARTIST DEREI.UK
            • V Offline
              vidy
              thanks jackson πŸ˜‰
              still so much to learn..
                rickymon
                @jakson said:
                Thanks Jackson, I wish I can learn to do those scripts too
                uploaded another test...
                take care
                  luciano.au
                  GREAT!!!
                  Best plugin ever!!
                  Solved all my problems.
                  Congratulations!!!
                    DesignChest
                    Great plug in . . . one thing. I am wandering what the best program is to stitch together the images for a mac. Imovie is driving me crazy and keeps zooming in and out of each individual frame. Any tips?
                    http://img823.imageshack.us/img823/2785/953499.png
                    • Chris FullmerC Offline
                      Quicktime all the way. It works fast and does a very good job.
                      All my Plugins I've written
                        BaffaloWing
                        Thank you very much : )
                        i think it very work πŸ˜„
                          Sebastien2
                          Wow, great!!!
                          • G Offline
                            Grice
                            Whaat, many many thanks for this and the person who replied to my post solving my little artifact problem that the programmers appeared not to be interested in fixing. Great script!
                            • F Offline
                              FS
                              how to install on mac..?
                                driven
                                same as any .rb files & theres lots of info on this forum.
                                download from the first post in this thread, move to 'plugins' folder
                                if it's hidden you can paste this into 'Ruby Console' under 'Window' menu in Sketchup
                                `open "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins"`
                                , then hit return/enter
                                drag the ruby in and restart SU.
                                john
                                • G Offline
                                  Gadgetguru
                                  thanks for the brilliant plugin!!
                                  using Proper Animation, Smoothstep & Adobe Lightroom and getting an excellent video
                                  is there any chance of adding support for exporting TIFF files?
                                  thanks πŸ˜„
                                  • P Offline
                                    pritishgajjar
                                    @pixero said:
                                    Thanks for a great script. πŸ˜„
                                    Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
                                    The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
                                    I believe this would make it work with external renderers.
                                    What do you think, is it doable?
                                    dear sir ,
                                    i m pritish from india , trying to render animation with vray can you make tutorial or may be some image/video format to explain your thoughts,it will be helpful .
                                    waiting for your replay.
                                    thanks in advance.
                                    regards,
                                    pritish
                                    • G Offline
                                      Grice
                                      I have been using this plugin for a while but have been running into a few problems, particularly on my PC (Mac to lesser extent). When generating frames, sometimes the frame generation can hang for a considerable amount of time. Standard frames will take a minute or two and then there will be a rogue frame that takes 20mins! Sometimes even as much as an hour! This ain't good. Seems to happen more at HD resolutions. It makes video generating times completely unpredictable.
                                      Some sort of feature to universally number frames so that the animation can be stopped/started or "farmed" to other computers without messing up the frame sequence would also be fantastic.
                                      I know this plugin was written a while ago but I am just hoping Whaat that you will relook at it again because it is a very useful script for my line of work...
                                      • duanekempD Offline
                                        duanekemp
                                        I see that the flow of additions to this post has slowed down. However, I've just read everything from the very beginning and curious if there is any further development on allowing this to work with rendering soft and plugins.
                                        I have searched SketchUcation, Google and spent too much time looking for an answer to the question that too many are asking. How to make smooth animation from SU scene camera positions. I have seen Rendering programs make smooth camera position transitions but cannot find the plugin that makes this an automatic feature for animation exports from SU. Here is an example of non smooth camera positions and I'm looking for the trick that avoids these choppy positions between camera points. Could this plugin one day help?
                                        I'd like to render animations with Thea and think this is really close to what we are looking for.
                                        https://www.youtube.com/watch?feature=player_embedded%26amp;v=NM978cZSj8c
                                        Duane Kemp
                                        Kemp Productions
                                        Puidoux, Switzerland
                                        Gallery:
                                        https://duanekemp.artstation.com/
                                        • sallyS Offline
                                          sally
                                          Hi Chris, do you mean Quicktime pro? And can you add still photos in between video clips or would you need to import the quicktime edited video into iMovie and do that in there? Thanks, best regards, Sally
                                            randomizer
                                            Can it be that exporting animations via write_image is slower than using regular export?
                                            Currently I am writing the connection to RenderPal, our renderfarm manager, and it seems that using this method for exporting is taking much more time.
                                            I observed that when using the the regular export, the 3d ui is completely paused. Maybe this might speed things up? But I was not able to pause it myself. Did not find a ruby function for that.
                                            Hope somebody can enlighten me a bit.
                                            Greetings
                                            Andreas
                                            • 3 / 4
