    [Plugin] Smoothstep Animation
    80 Posts 50 Posters 106.0k Views 50 Watching
      driven
      I've been trying this out and had two very different results re: output quality (they're both up on youtube, link to one here...
      http://www.youtube.com/watch?v=YMRfjRsIQ7g&layer_token=9015d6617d71c051
      the first was made was made manually from 12 layers containing 12 instances (re-named) at 15ΒΊ of rotation, made using xformclone.rb (fantastic...)
      I tranfered this at (640x480 12 fps jpg >1) into iStopmotion so I could remove the 6-8 dead frames between each layer swop, I also batch cropped, and did a half speed test by dropping more frames, I'm very happy with the results...
      the 2nd was a linear motion test with a single incident component (but much hire poly-count), on only one layer. Steps were achieved using mover.rb and tying the object to and the green axis with the rotate tool, scroll wheel clicks were used for spacing... the movement look acceptable on screen but SU frose when transferring at the previous settings... I turned the frame rate up... and then down... crashed SU... I removed xformclone and standard views just in case, sill frose during transfer, I then stripped out the clip, used your default settings and finally got a set out..
      Each try did output jpgs, all of equally bad quality, any thoughts?
      I tend to think that more organised layering(with sub folders) will always give a better quality result, if you take out the lag or play to it.
      I haven't tried out putting with proper_animation.rb yet as I needed to get my head around the basic functionality of using scenes first.
      Anyway I was very impressed with output quality on the first one and for any mac user iStopMotion and iMovie make post-production and posting to YouTube a breeze..
      cheers
      16KB
      12KB
        rickymon
        Hey guyz
        I know this is an old thread, but just for you to know...
        Was looking for a plugin to animate objects, and I found Properanimation.rb by morisdov
        This is a very cool plugin but did not have any way to export, native SU export engine did not support it. There are hughe threads about this issue, other people was considering to make screencapture videos, or get fancy external render engines.
        But guess what...?
        Smoothstep Animation not only exports smooth camera scenes, it also recognizes all Properanimation.rb animations.....!!!!
        So if you are looking for a cool tool to animate objects, try both plugins
        Properanimation.rb + SmoothstepAnim.rb
        Uploading utube
        http://www.youtube.com/watch?v=UL6tnTvphAE
        Done
        • jcdbJ
          jcdb
          Created with Smoothstep Animation
          http://www.acustombuilder.com
          • romboutR
            rombout
            @rickymon said:
            Hey guyz
            But guess what...?
            Uploading utube
            Done
            but how did you get to export all geometry, cause i thought he said i could only export images???
              rickymon
              @rombout said:
              @rickymon said:
              Hey guyz
              But guess what...?
              Uploading utube
              Done
              U can make a video out of a sequence of images, twhat I didnt knew is that both plugins were compatibles. So u dont need any fancy external engine to export smooth transitions and object animation. Unless u wanna go photorealistic. }
                Jakson
                I made as well some small change to the script, I hope you don't mind.
                Added support of saving the Export Property's to the Model.
                If you cancel the export dialog or the save dialog the script stops instantly.
                And reduced the filenumber padding to 6 numbers.
                And my first Animation with Properanimation + SmoothstepAnim http://www.youtube.com/watch?v=agCUtjEJssM
                smoothStepAnim.rb
                • dereiD
                  derei
                  Is it a similar plugin to this one http://forums.sketchucation.com/viewtopic.php?f=323&t=33417 ?
                  DESIGNER AND ARTIST DEREI.UK
                  • V
                    vidy
                    thanks jackson πŸ˜‰
                    still so much to learn..
                      rickymon
                      @jakson said:
                      Thanks Jackson, I wish I can learn to do those scripts too
                      uploaded another test...
                      take care
                      • L
                        luciano.au
                        GREAT!!!
                        Best plugin ever!!
                        Solved all my problems.
                        Congratulations!!!
                          DesignChest
                          Great plug in . . . one thing. I am wandering what the best program is to stitch together the images for a mac. Imovie is driving me crazy and keeps zooming in and out of each individual frame. Any tips?
                          http://img823.imageshack.us/img823/2785/953499.png
                          • Chris FullmerC
                            Quicktime all the way. It works fast and does a very good job.
                            • B
                              BaffaloWing
                              Thank you very much : )
                              i think it very work πŸ˜„
                                Sebastien2
                                Wow, great!!!
                                • G
                                  Grice
                                  Whaat, many many thanks for this and the person who replied to my post solving my little artifact problem that the programmers appeared not to be interested in fixing. Great script!
                                  • F
                                    FS
                                    how to install on mac..?
                                      driven
                                      same as any .rb files & theres lots of info on this forum.
                                      download from the first post in this thread, move to 'plugins' folder
                                      if it's hidden you can paste this into 'Ruby Console' under 'Window' menu in Sketchup
                                      `open "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins"`
                                      , then hit return/enter
                                      drag the ruby in and restart SU.
                                      • G
                                        Gadgetguru
                                        thanks for the brilliant plugin!!
                                        using Proper Animation, Smoothstep & Adobe Lightroom and getting an excellent video
                                        is there any chance of adding support for exporting TIFF files?
                                        thanks πŸ˜„
                                        • P
                                          pritishgajjar
                                          @pixero said:
                                          Thanks for a great script. πŸ˜„
                                          Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
                                          The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
                                          I believe this would make it work with external renderers.
                                          What do you think, is it doable?
                                          dear sir ,
                                          i m pritish from india , trying to render animation with vray can you make tutorial or may be some image/video format to explain your thoughts,it will be helpful .
                                          waiting for your replay.
                                          thanks in advance.
                                          regards,
                                          pritish
                                          • G
                                            Grice
                                            I have been using this plugin for a while but have been running into a few problems, particularly on my PC (Mac to lesser extent). When generating frames, sometimes the frame generation can hang for a considerable amount of time. Standard frames will take a minute or two and then there will be a rogue frame that takes 20mins! Sometimes even as much as an hour! This ain't good. Seems to happen more at HD resolutions. It makes video generating times completely unpredictable.
                                            Some sort of feature to universally number frames so that the animation can be stopped/started or "farmed" to other computers without messing up the frame sequence would also be fantastic.
                                            I know this plugin was written a while ago but I am just hoping Whaat that you will relook at it again because it is a very useful script for my line of work...
                                            • 3 / 4
