    Import autocad 3d curve solid
    5 Posts 3 Posters 857 Views 3 Watching
    • S
      sjgb
      Have some trouble importing autocad curved solid because some faces of the solid dissapear, i have already tried changing the import options in sketchup but the problem is still there, do i need to change something in my autocad settings so it works in sketchup?
      • W
        watkins
        Try scaling up your AutoCAD model x100 before exporting, then import into SU, and then scale back 0.01. I am assuming that you are trying to import a 3D model.
        Regards,
        Bob
        • P
          PRSS
          Thank you Watkins, It sort of solved my long term problem. But with too many curved entities, and also with double curved objects (meaning it has a curved surface with a bulge also)it still gives problems.
          But this is really of a great help for me.
          Thanks once again
          With best regards
          PRSS
          • W
            watkins
            You might need to scale up even more, say x 10,000. Worth a try.
            • S
              sjgb
              Thanks i will try that!
