    Holes, holes, holes...
    6 Posts 3 Posters 738 Views 3 Watching
    • N
      numbers
      How do I put holes into existing drawings? Say for like drainage or wires.
      • N
        numbers
        Would it make an empty hole?
        • GaieusG
          By this time you could've tried! πŸ˜‰
          Yes. If not, just delete the unnecesar face.
          • N
            numbers
            ok I don't get it.
            I have a flat face, I have a circle where I want the hole to be, but I don't know how to turn it into a hole.
            • GaieusG
              Right click on the face of the circle and choose "Erae" from the context menu.
              • H
                Hazza
                If it is already a component or group first you have to:
                1. Explode it, OR
                2. Double click the item to edit it
                THEN you can draw the circle to push/pull it. If you just erase the circle all you do is have a hole in the face of the item. If you want it so that there is a face on the inside of the item then you need to push/pull it.
                Have a look at the demo model.
                circle-demo.skp
                See all of my SketchUp models here.
