    Plugin
    20 Posts 11 Posters 2.4k Views 11 Watching
    • R
      rogerra
      I saw a plugin "ruby script" for a spiral stair but can't seem to find it again.
      I'd like to add it to my plugins folder.
      Where can I find it?
      • GaieusG
        Hi Rogero,
        spiraltair.rb can be found here (scroll down).
        • R
          rogerra
          Thanks.
          I see them but when I click on either link to download it does not work.
          I guess they are not available anymore.
          • Didier BurD
            Didier Bur
            Right-click on the file name and select "Save link target as".
            DB
            • R
              remus
              Both the links go to an error page...
              • P
                pmiller
                Not for me
                • R
                  remus
                  Hmmm, very strange, theyre still broken for me. I wonder if it is location dependant?
                  • StinkieS
                    Stinkie
                    It's personal, Remus. The links frown upon you and your ways.
                    • Chris FullmerC
                      They don't work for me either.
                      All my Plugins I've written
                      • J
                        Jim
                        The links are incorrect. They link to the ruby files, and should end in .rb. If you add the .rb in the address bar of the browser after you click the link, you can download the files.
                        • R
                          rogerra
                          I click on the link and when it goes to the error page, I then add the .rb in the address window. It then opens the code.
                          All I can do is "select all" and copy to the clipboard.
                          Then I can past into wordpad but can only save as a .txt file.
                          How do I make it an .rb file?
                          • R
                            remus
                            Just change save the file as .txt, then right click the file->rename and then change it to .rb.
                            • Alan FraserA
                              Alan Fraser
                              ...or just click off the file type "text" and select "any". That way, it won't add a .txt extension after the .rb
                              3D Figures
                              • plot-parisP
                                plot-paris
                                an alternative could be to use a newly created script by AdamB. it looks at the difference in position/rotation/scale of two components and creates multiple copies with the same transformations applied to each copy in relation ship to the previous one.
                                you can find it in this thread.create a component of the first step of your spiral stair case. create a copy, move it up and rotate it around the stairs' centre.
                                then right-click the first step-component and choose "Play it again", type in the number of desired steps, followed by "x" (15x for example), then left-click the second component...
                                thats it, you have a spiral stair case 😄
                                • R
                                  rogerra
                                  I don't get it. I have the .txt file but renaming it to spiralstair.rb does not change the type.
                                  Under "rename" and "properties" it still shows as a text file, not an rb file as my other plugins do.
                                  I can't find any "all" option by right clicking.
                                  I tried taking an existing .rb file and saving it as a new name. Then deleting the text and pasteing the spiral stair text into it. It did't work.
                                  What am I doing wrong?
                                  • J
                                    Jim
                                    Stupid Windows... You need to turn off this Folder Options option before renaming extensions:
                                    • R
                                      rogerra
                                      Thanks Jim. That did the trick.
                                      • R
                                        rogerra
                                        Well, I got it installed correctly.
                                        Now, how do I get it to work. It says select two curves (what curves?) and then what.
                                        I drew 2 circles with a 1.5' radius, selected them and got a weird cone shape.
                                        • R
                                          RickW
                                          See this thread and this thread for discussions and examples.
                                          Hope that helps,
                                          RickW
                                          www.smustard.com
                                          • R
                                            rogerra
                                            I think I'll stick to making my spiral stairs in "Datacad" and importing them into sketchup.
                                            This works great for me. It includes a handrail, etc.
