    I just bought subdivide and smooth.
    15 Posts 6 Posters 2.8k Views 6 Watching
      Tekkybot
      loving it
      • K Offline
        kwistenbiebel
        He he ....now that is what I call a happy posting. πŸ˜„
        I am glad you like that plugin. It is indeed a special one.
        • plot-parisP Offline
          plot-paris
          Tekkybot, you know that with starting this thread you commited to posting some images of your first results with Subdivide&Smooth πŸ˜‰
            Agree! πŸ˜‰ <- not vicious wink
              Tekkybot
              πŸ˜„ ill post my results with the plug at the end of the day. don't expect much though πŸ˜›
                Tekkybot
                heres my first result. im only posting it cause im excited about the plugin. im going for a mushroom 😎 this time i think the model will get finshed fingers crossed πŸ˜‰
                http://www.megaupload.com/?d=ESJOHBZ9
                  plot-paris
                  I am unfortunately not able to see the image. only get a link to megaupload.com (with some advertisment)
                    Same here.
                      marne
                      @gaieus said:
                      Same here.
                      Have a look at the upper left corner of the site, there you could type a verification code for downloading πŸ˜„
                        plot-paris
                        ah, I see. thanks marne.
                        but Tekkybot, I would suggest you upload pictures in future, because it is so easy to have a look at them and see your work instead of downloading the file (after waiting for 45 seconds), unzipping it, opening it with SketchUp (which slowes down your system). like this:
                        http://img296.imageshack.us/img296/1872/tekkybotta3.jpg
                        in case you don't have a preferred server for image upload, imageshack.us is fairly slow, but reliable. when you uploaded a picture you get some links. copy the bottom most one. when you write your post here in the forum, press the "Img" button at the top of the text window and insert the copied link into the brackets.
                        I took the liberty to to a quick render with your model - a nice start with S&S by the way - hope you don't mind. only applied some reflection to object and ground plane and left it for render with su podium for less than 10 minutes...
                          Tekkybot
                          wow plot that looks really cool πŸ‘ i got to get some rendering software. but first i need to finish a model πŸ˜›
                            Tekkybot
                            @tekkybot said:
                            ill remember this. thanx πŸ‘
                              Tekkybot
                              will do πŸ˜„im working on a shroom πŸ˜‰
                              • soloS Offline
                                solo
                                Attached is a proxy (base shape) of a mushroom, select all and apply 3 iriterations to it and it will appear.
                                This is so you can get an understanding as how to create proxy's that will 'sub-smooth' to a shape you are happy with.
                                Then you can texture and render it (your next challenge)
                                Mushroom rendered
                                http://img84.imageshack.us/img84/7352/mushroomgg9.jpg
                                mushroom proxy.skp
                                http://www.solos-art.com
                                  Tekkybot
                                  thanx solo πŸ‘
