    Can sketchup be used for 100% accurate sun studies?
    3 Posts 3 Posters 1.8k Views 3 Watching
      j_forrester
      As the title says, can this really be used in an architectural environment for planning and rights of lights studies?
      Many thanks.
      • Alan FraserA Offline
        Alan Fraser
        I think this question was asked a couple of releases ago; and the concensus seemed to be that unless there is something wrong with your setup then yes...it's about as accurate as you could hope for.
        I used it to test for shadows on a new-build squeezed onto a rather small vacant lot at the back of my own property. I suspected (and SU confirmed) that our house would shade the entire lower floor of the proposed property right through the darkest winter months. Sure enough.....
        3D Figures
          Also, Jim Foltz made a plugin that "Plots the path of the Sun usinng Construction Points."
          It may be useful if you are thinking about such things.
