    How to Change Feet to Millimeter?
    11 Posts 6 Posters 21.8k Views 6 Watching
      Bob Bean
      Hi all I was wondering if there is a way to change the scale of measurement from Feet to mm.
      I have a skp.template that I have downloaded and it is set to feet and inches, yet the plans I want to import and and the scale I want to work in will be Millimeters!
      When I draw a line the length show is as the template setting of ( ' & ") But I need to change that to mm.
      Is there away of changing the template measurement? I have changed the "Preferences" to mm but when drawing a line it is still displayed as ' & ".
      all help appreciated
      Bob
        johnsenior1973
        Do you have a "Untitled" model saved that SU opens to? For example, I don't see the point of Bryce appearing every time SU starts, so I deleted Bryce, then saved the model "Untitled" with nothing in it. Now when Sketchup starts, Bryce doesn't appear.
        If you don't have an Untitled model saved, then SU will probably start with all the default settings - incl feet and inches.
        If you do have an Untitled model, change the settings to mm, then save that empty model. Then when SU opens it should automatcially be with mm settings.
        Hope that helps.
          Bob Bean
          To try and explain a bit more, I'm not brilliant at explaining...
          I have no problem with my default template ( untitled ), that opens with mm all good and well.
          But when I open a specific template setup (http://www.aboveallhouseplans.com/APV_Template.zip) the one supplied by Krisidious for his tutorial How a Pro Builds a House in Sketchup Part 1, all measurements change back to feet/inches as that is what his template is created and saved as such. In would like to force his template into mm. So I open his template(' & "), import my floor plan as an image (mm) and try to measure up my diagram it then shows lengths as ' &" .!! grrrrr
          cheers again
          bob
            johnsenior1973
            I'd say you should open his model, change the measurements to mm, save the model. Close Sketchup. Then open up Sketchup again. Open the saved model, then that should be in mm and fine for you to import your image into.
              Bob Bean
              Thanks John
              But no! I have just retried this again . Open his .skp file - change preferences to mm - save as ### - open new file ### - check preferences( yep they are in mm)- use tape measure tool. Still displays distance in feet and inches!
              At a loss and don't want to revert to working in Imperial. There surely must be a way around this. There must.
              cheers again
              bob
                Bob Bean
                Found it!!
                Change it in Window >Model Info> Units
                whoo hoo
                thanks all
                Bob
                • Chris FullmerC Offline
                  EDIT: I missed some of his post I guess. This post is not quite on topic I suppose....
                  There is also a default template already made that you can choose to use that will always be in mm. on a PC, go to Window>Preferences>Template and choose the mm one. Then next time you start SU it will start in mm.
                  Chris
                  All my Plugins I've written
                  • P Offline
                    PolySTUDENT
                    How can a mm template be created on a Mac?
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi Paul, hi folks.
                      On a Mac, you do exactly like on a PC.
                      Use Window menu --> Model info --> Units.
                      Choose the type of unit in the rightmost pull down list (inches, feet, millimeters, centimeters, meters) and then the format in the pulldown list to the left of the other one. Notice that the available formats are dependent on the type of unit. Fractional do not applies to mm, cm and m.
                      Then you can choose the precision that will be shown from 0 to 6 decimals.
                      While at it, I suggest to uncheck the box labeled Enable length snapping. I use that very rarely since SKetchUp allows very precise positioning of objects.
                      By the way, all this is in the help that you can each using the Help Menu --> Help Center.
                      Just ideas.
                      • P Offline
                        PolySTUDENT
                        Hi Johnny,
                        Thanks. There's such a huge volume of new things to learn. Your help is greatly appreciated!
                        Paul
                          Theten
                          i have a problem
                          when i write this code:
                          Create the WebDialog and set its HTML file
                          face_dialog = UI::WebDialog.new
                          path = Sketchup.find_support_file "Ch13/create_face.html", "Plugins"
                          face_dialog.set_file path
                          Set the WebDialog's callback
                          face_dialog.add_action_callback("create_face") {|d, arg|
                          if arg.to_s.length == 0
                          puts "Invalid input. Coordinates must be valid numbers."
                          else
                          v = arg.to_s.split(",")
                          pt1 = Geom::Point3d.new(Float(v[0].strip), Float(v[1].strip),
                          Float(v[2].strip))
                          pt2 = Geom::Point3d.new(Float(v[3].strip), Float(v[4].strip),
                          Float(v[5].strip))
                          pt3 = Geom::Point3d.new(Float(v[6].strip), Float(v[7].strip),
                          Float(v[8].strip))
                          pt4 = Geom::Point3d.new(Float(v[9].strip), Float(v[10].strip),
                          Float(v[11].strip))
                          vec1 = pt2 - pt1
                          vec2 = pt2 - pt3
                          plane = [pt1, vec1 * vec2]
                          if pt4.on_plane? plane
                          Sketchup.active_model.entities.add_face pt1, pt2, pt3, pt4
                          else
                          puts "Invalid input. Points must lie on the same plane."
                          Display the dialog box
                          if RUBY_PLATFORM.index "darwin"
                          face_dialog.show_modal
                          else
                          face_dialog.show
                          the unit appare in inches but mi template in setting in mm.How i can have it in mm?
                          thanks and sorry for my english
