    [Plugin] GreyscaleMode
    133 Posts 56 Posters 149.3k Views 56 Watching
      sepo
      Aha...cheers Dave did not pick that up...Cool. Any chance to actually have more than 10 shades of grey. That would make renders nicer.
        As I understand it, Jim's method of creating the gray values is to average the RGB values and apply that number to all of the RGB settings. I don't think we're limited to 10 steps as was discussed in the other thread.
          sepo
          Actually I think you are correct ... discard the last bit πŸ˜‰
          • utilerU Offline
            utiler
            I like it and thanks, but can't this be done using a Style?
            I agree, Coen. A face style. That way we could save it to styles and scenes.....
            It wound allow us to 'revert color' in a style / scene though I wouldn't think..... Jim?
            Just Curious...
            • Z Offline
              zed252000
              TY " You're Good !!"
              Whatever we IMAGINE....
                Jim
                Thanks and you're welcome, everyone.
                Having it work as a Face Style would be nice. Face Styles can be selected in Ruby by setting an option called the RenderMode. There is just not a way to create a new Face Style that I can see.
                Like Dave said, I don't think a Style is an option either. There is no control over individual colors in a Style.
                The idea of saving material changes between Scenes is a completely separate plugin...
                • utilerU Offline
                  utiler
                  You're right Jim, that's the only thing that restricts it from being a 'face style' option. It would be nice to be able to "update scene" individually rather than a ruby that effects the model period....but that takes away from the "reverse color" option....
                  I guess if this was a face style and we wanted to 'spot color' an element, we could set up diferent components and scenes then import into Layout and overlay scenes.....a round about way of doing things though and getting into another topic, 'more than one style in a drawing / file'.
                  Five Star, Jim.
                  Just Curious...
                  • Z Offline
                    zed252000
                    πŸ‘Š
                    this is just Awesomely Good.
                    Thanks!
                      Jim
                      Hi Guys,
                      A word of caution; utiler has reported he was not able to get the right-click "revert" color option using this plugin. I'm not sure why, but it may mean that the script could "forget" your original material colors. I'm looking into it.
                      EDIT: There is no danger of loosing the original colors. The error was caused because the default color returns nil when asked for its material.
                        Jim,
                        Thanks for the warning. I haven't seen that problem but I'll keep my eyes open and let you know.
                        Dave
                        • Didier BurD Offline
                          Didier Bur
                          This happens when the face has default material, here is the error message:
                          Error: #<NoMethodError: undefined method `get_attribute' for nil:NilClass>
                          because in the code, line 16:
                          material = sel.material -> equals nil when no material on face
                          then line 18:
                          rgb = material.get_attribute("GreyScaleColors", 'rgb')
                          get_attribute method can be used on nil πŸ˜‰ and then no context menu.
                          This would be better:
                          if sel.typename == "Face" and sel.material
                          This is impossible IMHO... Attributes on non-geometric objects such as layers and materials, once set, cannot be accessed by the user, lost, erased, or forgotten, unless the script itself does erase them.
                          Last note: I've been told that (red+green+blue)/3 does not give an exact gray value. What Gimp or PS do to desaturate an image for instance is:
                          gray_value=([red,green,blue].max + [red,green,blue].min)/2.0
                          Sketchup::Color.new( gray_value, gray_value, gray_value )
                          My 2 cts (of Euros πŸ˜„ )
                          DB
                            Jim
                            The plugin goes through all in-model materials and changes them to a grey value. The default face color is completely ignored as it does not appear in the in-model materials list, and this is when the material is nil.
                            So the question is, should the plugin also change the default face color to a grey value?
                            Does anyone have a preference for how the greyscale value is calculated? If not, I will try the method suggested by Didier.
                            Thanks, Didier for taking the time to help.
                            • utilerU Offline
                              utiler
                              I never export images, etc from SU with the default face color. In fact if we did this in grey scale without adding additional color to the scene then grey scale would be a constant....
                              Here is another nice example of grey scale output. [not mine]
                              Just Curious...
                                I guess I'm not too picky about how the grays are determined. At this point the average of the RGB values seems to work fine but if there's another option, I'm willing to go that way. As far as the default material being turned to a gray, perhaps it could be left alone? THis would make it easier to identify faces that haven't been given a material.
                                • utilerU Offline
                                  utiler
                                  True Dave, the default color can go it alone....
                                  As for grey scale variation, If we didn't have variation i think it would shade quite bland IMHO...
                                  Just Curious...
                                    Andrew, you have a point about the potential for blandness. (I think I just made up a word.)
                                    I'm sure it would add to the complexity of the plugin but suppose one could choose some sort of filter factor. Suppose that you want to simulate a 25 Red filter. You might choose Red from a list of filters which would give green colors lower values (make them darker) while reds would tend to be higher values. This would give you the ability to tune the grays to prevent some colors from being too close together on the gray scale.
                                      Here's another example of using the Grayscale Plugin. This is raw SU output.
                                      http://img.photobucket.com/albums/v506/weekender410/RBT.jpg
                                      • utilerU Offline
                                        utiler
                                        Awesome Dave!!!
                                        Just Curious...
                                          Thank you Andrew. There's not much color in this model anyway but I like the effect with the grey scale option. I like that the wood grain still shows this way, too.
                                          • plot-parisP Offline
                                            plot-paris
                                            @dave r said:
                                            ...but suppose one could choose some sort of filter factor. Suppose that you want to simulate a 25 Red filter. You might choose Red from a list of filters which would give green colors lower values (make them darker) while reds would tend to be higher values.
                                            do I understand it correctly that with this method you could even create a sepia effect (with some colours standing out of course πŸ˜‰ ). that would be such a cool thing!
                                            • 6
                                            • 7
                                            • 2 / 7
