    Hi! iRender vs Vray?
    7 Posts 5 Posters 4.1k Views 5 Watching
    • E Offline
      evilelvis
      Hi all!
      This forum is worth much more than years of study! πŸ‘
      My first question - Which is better? iRender or Vray?
      I've been using Vray and it seems to be ok to learn whereas iRender seems more user friendly πŸ˜•
      Thanks in advance!
      http://www.coroflot.com/MDVee
        Hi EE,
        This is always a hard to answer question as some people are more familiar with this while others with that application. The conclusion of such comparisons has always been that you cannot really compare rendering programs.
        So I won't answer you but if others chime in, you will se that the above statement is right. πŸ˜„
        • FrederikF Offline
          Frederik
          Gaieus is absolutely right..!! πŸ‘
          But if we take your own statement...
          There's no doubt that iRender has a more intuitive and thereby more userfriendly approach...
          Having said that, I'm sure many will agree with me when saying that Vray is a well known application and have almost a "de facto" status within rendering software...
          Perhaps you should look at something in between...?!?
          Podium is generating some high quality renders, but is also well known for being very userfriendly..!! πŸ˜‰
          Cheers
          Kim Frederik
          • E Offline
            evilelvis
            Thanks for your prompt replies -
            I'm gonna teach myself both Vray and iRender
            Podium is another EE friendly prog indeed..i've used it for 2 years now and was wanting to go more 'professional' with more 'name brand' renderers such as Vray etc πŸ’š
            many thanks!
              JuanV.Soler
              HI
              evilelvis,
              if you take this question in the SKETCHUP DISCUSSIONS forum instead of this one about the Newbyes, maybe be you will get more opinions about this fight worth to hear.
              maybe.
                chango70
                Well having had a go at Podium, Vray and iRender I'd have to say Vray is without a doubt the best renderer out of the three. The so called steep learning curve applies only when you want to do advanced material manipulation like refraction etc. You can just press render without any change to setting and due to having a global illumination setting by defualt the results are always decent. Also Vray has a very good and active forum for learning how to do advanced stuff.
                • E Offline
                  evilelvis
                  Chango..you're spot on about Vray..it also has a great PDF manual too! πŸ‘
