    [Plugin] Lines to tubes
    131 Posts 61 Posters 293.0k Views 61 Watching
      johnsenior1973
      Deleting the lines2cyl ruby did sort out the problem.
      • Didier BurD Offline
        Didier Bur
        Hi all,
        Sorry for the inconvenience of the "not showing plugin" problem. My fault. You must delete old "line2cyl.rb" of your plugins folder OR I must correct the name of the plugin in the code (I forgot to change it). If line2cyl is loaded first, SU doesn't create another menu item in the tools menu for the new version.
        would be possible to modify so we could extrude along square shapes as well?
        Use a precision of 4 and you'll get square section prisms.(RTFM)
        please restore this function in "projection_extension.rb
        Does this make sense ? This function has nothing to do with projection IMHO...
        I was wondering if there is way to clean up intersection...
        The script can't do it (I mean, quite difficult to code). A workaround is to draw as much curves as you can, and select "Yes" in the "follow-me on curves" option. But it cannot clean intersections on T or Y or X branching edges.
        Maybe next version will do it ?
        DB
        • FrederikF Offline
          Frederik
          THANKS A LOT, Didier..!!
          http://www.kerkythea.net//users/Frederik/Anim-Icons/praise.gif
          Cheers
          Kim Frederik
            dylan
            Thanks Didier.
            Could this be adapted to use a semi-circle with thickness? I am thinking of use for ridge tiles on a roof.
            http://dmdarchitecture.co.uk/
            • urgenU Offline
              urgen
              ...HA!...good idea,Dylan! ๐Ÿ˜‰ ๐Ÿ˜„
              --pupil forever...------
              • ely862meE Offline
                ely862me
                ๐Ÿ‘ ๐Ÿ˜
                Another piece of....what????...lets say Pandoras box!!
                This will help me to make tubular chassis instead of what i was making before.
                ๐Ÿ˜‰
                Thank you Mr. Didier!!
                Elisei
                Elisei (sketchupper)
                Come and See EliseiDesign
                • utilerU Offline
                  utiler
                  @sepo said:
                  for the problems, maybe you must disable the old "line2cyl.rb"?
                  maybe...
                  for me it works with old tool....
                  Thanks Didier for a very usefull plugin... I was wondering if there is way to clean up intersection...
                  Ditto Sepo, I found the same thing...
                  Just Curious...
                  • 2 Offline
                    2myChaGrin
                    Thanks so much Didier! You just made my life so much easier!
                    • boofredlayB Offline
                      boofredlay
                      for the problems, maybe you must disable the old "line2cyl.rb"? ๐Ÿ˜‰
                      maybe...
                      I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up.
                      Thanks. ๐Ÿ‘
                      • MarianM Offline
                        Marian
                        i think there should also be an option to make not round tubes but square hexagonal triangular ones.
                        • G Offline
                          gaucho
                          Simple anD easy.. MERCI!
                          "eat well, stay fit, die anyway..."
                          • jujuJ Offline
                            juju
                            I think if you downloaded the plugin and checked the manual you'd see that it already does what you want.
                              Didier Bur
                              Read the doc and USE PRECISIOn ๐ŸŽ‰ !!!
                              You beat me on this Juju !
                              DB
                                CameronVan
                                maybe...
                                Thanks. ๐Ÿ‘
                                Ahhh, great.
                                Thanks Pilou!
                                • MarianM Offline
                                  Marian
                                  Silly me....i did download the plugin and tried it before posting that...which makes me a bigger fool...but i didn't try the options...and manuals...who ever reads them? ๐Ÿ˜›
                                    Didier Bur
                                    Those who don't want to bother doc writers ๐Ÿ˜†
                                    DB
                                      lorca
                                      Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
                                        lexmonteiro
                                        Great plugin, I was trying to create a window and realized that using precision 4, the corners were at 45 degrees, can I control the orientation of the angles?
                                        Thanks!
                                          chango70
                                          Doesn't show up for me. I don't have older version at all. Any ideas?
                                          • X Offline
                                            xrok1
                                            i just DLd and it showed up in tools menu.
                                            thanks dedier! ๐Ÿ˜„
                                            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                            • 6
                                            • 7
                                            • 2 / 7
