    [Plugin] Lines to tubes
    131 Posts 61 Posters 289.9k Views 61 Watching
    • urgenU Offline
      urgen
      ...thanks,Didier!...I expected it for a long time! πŸ˜‰ πŸ˜„
      --pupil forever...------
        rv1974
        Very nice Didier, thanks
        Additionally may be you could:
        1/ add a rotation parameter (when precision is 4 one would get square section (rotation 45))
        2/now I weld lines to get continuous result. Any chance to get it automatically?
        3/conjunctions?
        • urgenU Offline
          urgen
          for the problems, maybe you must disable the old "line2cyl.rb"? πŸ˜‰
          maybe...
          ...yes! "line2cyl.rb" should be deleted πŸ˜„
          ...Didier, please restore this function in "projection_extension.rb" πŸ˜‰
            johnsenior1973
            Deleting the lines2cyl ruby did sort out the problem.
            • Didier BurD Offline
              Didier Bur
              Hi all,
              Sorry for the inconvenience of the "not showing plugin" problem. My fault. You must delete old "line2cyl.rb" of your plugins folder OR I must correct the name of the plugin in the code (I forgot to change it). If line2cyl is loaded first, SU doesn't create another menu item in the tools menu for the new version.
              would be possible to modify so we could extrude along square shapes as well?
              Use a precision of 4 and you'll get square section prisms.(RTFM)
              Does this make sense ? This function has nothing to do with projection IMHO...
              I was wondering if there is way to clean up intersection...
              The script can't do it (I mean, quite difficult to code). A workaround is to draw as much curves as you can, and select "Yes" in the "follow-me on curves" option. But it cannot clean intersections on T or Y or X branching edges.
              Maybe next version will do it ?
              DB
              • FrederikF Offline
                Frederik
                THANKS A LOT, Didier..!!
                http://www.kerkythea.net//users/Frederik/Anim-Icons/praise.gif
                Cheers
                Kim Frederik
                  dylan
                  Thanks Didier.
                  Could this be adapted to use a semi-circle with thickness? I am thinking of use for ridge tiles on a roof.
                  http://dmdarchitecture.co.uk/
                  • urgenU Offline
                    urgen
                    ...HA!...good idea,Dylan! πŸ˜‰ πŸ˜„
                    • ely862meE Offline
                      ely862me
                      πŸ‘ 😍
                      Another piece of....what????...lets say Pandoras box!!
                      This will help me to make tubular chassis instead of what i was making before.
                      πŸ˜‰
                      Thank you Mr. Didier!!
                      Elisei
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                      • utilerU Offline
                        utiler
                        maybe...
                        for me it works with old tool....
                        Thanks Didier for a very usefull plugin... I was wondering if there is way to clean up intersection...
                        Ditto Sepo, I found the same thing...
                        Just Curious...
                        • 2 Offline
                          2myChaGrin
                          Thanks so much Didier! You just made my life so much easier!
                          • boofredlayB Offline
                            boofredlay
                            maybe...
                            I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up.
                            Thanks. πŸ‘
                            • MarianM Offline
                              Marian
                              i think there should also be an option to make not round tubes but square hexagonal triangular ones.
                                gaucho
                                Simple anD easy.. MERCI!
                                "eat well, stay fit, die anyway..."
                                • jujuJ Offline
                                  juju
                                  I think if you downloaded the plugin and checked the manual you'd see that it already does what you want.
                                    Didier Bur
                                    Read the doc and USE PRECISIOn πŸŽ‰ !!!
                                    You beat me on this Juju !
                                    DB
                                      CameronVan
                                      maybe...
                                      Thanks. πŸ‘
                                      Ahhh, great.
                                      Thanks Pilou!
                                      • MarianM Offline
                                        Marian
                                        Silly me....i did download the plugin and tried it before posting that...which makes me a bigger fool...but i didn't try the options...and manuals...who ever reads them? πŸ˜›
                                          Didier Bur
                                          Those who don't want to bother doc writers πŸ˜†
                                          DB
                                            lorca
                                            Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
                                            • 2 / 7
