    Turn 3D model dimensions into a text file?
    16 Posts 6 Posters 3.5k Views 6 Watching
    • M
      Metterz
      I'm doing a program for computing at college, and I need to input dimensions of 3D objects. It'd be great if I could make models of objects in Sketchup then have it generate a simple text file from which another program could read dimensions, for eventual use in visual basic for MS Access. For now, none of the objects will have any curved edges.
      The text file will have to include dimensions of all the 3D objects drawn in a Sketchup file, preferably with some sort of reference number or name for each object.
      I have no coding experience with Sketchup, so any ideas, code or solutions will be greatly appreciated.
      Thanks!
      • jujuJ
        juju
        IIRC there is someone here on the SCF working on a project whereby there is an exchange of information between SketchUp and Excel (probably a CSV file generated).
        • T
          toxicvoxel
          An option may be to export to dxf and parse the object text data from there.
          It will however require you to write a dxf parser if you can't use any commercial dxf object reader in your project. Not too difficult to do once you understand the dxf file structure.
          • TaffGochT
            TaffGoch
            Metterz,
            As toxicvoxel suggests, I commonly use DXF to both import and export a text file describing lines, endpoints and faces. Note that most DXF files are text files. (Some can be binary, but SketchUp will export the ASCII text version.)
            You can use a text editor, if the model is not too complex, but I also (more often) use Excel. You can learn about the DXF format at the AutoDesk website:
            ASCII DXF File Format
            Regards,
            Taff
            "Information is not knowledge." -- Albert Einstein
            • GaieusG
              I am a total non programmer but the collada (*.dae) file SU is capable to export is also a text file (in *.xml format).
              XML format is becoming kind of "popular" nowadays, too. The advantage of it is that even the free version of SU exports it - hidden in the kmz file which is actually a zip file (you can rename it and open it to see within the model folder).
              • J
                Jim
                Do you mean simple width, depth, and height information? If so, then you could use Groups to specify each "thing" and export its overall dimensions to a text file.
                • M
                  Metterz
                  Ok there's no way I can afford SU Pro to export anything other than .kmz files. Is it possible to make a text file without exporting files, eg. using Ruby?
                  • M
                    Metterz
                    And besides, the program's meant to be written for an end user, so the SU part of the whole thing has to be the freeware version...
                    Thanks all for your help
                    • J
                      Jim
                      Yes, it's possible, but it's not clear to me exactly what data you need as the output?
                      • M
                        Metterz
                        Just a string of numbers will probably do, like maybe co-ords of each corner of each group/component. I just need some text file data that MS Access can use to easily acquire the dimensions of groups/components in a SU file. It will probably easier if I can make an Excel spreadsheet though, instead of a text file.
                        I don't know how the contents of the dimensions file will be arranged, but i'll try to work with whatever I can get out of the SU model
                        • J
                          Jim
                          At a basic level, this will do what you need.
                          outfile = File.new( "c;\\output.csv", "w")
                          Sketchup.active_model.entities.each do |e|
                            next unless e.is_a? Sketchup;;Group or e.is_a? Sketchup;;ConponentInstance
                            bbox = e.bounds
                            0.upto(7) do |i|
                              c = bbox.corner(i)
                              outfile.print "#{c.x.to_f},#{c.y.to_f},#{c.z.to_f}\n"
                            outfile.puts "\n"
                          outfile.close
                          • M
                            Metterz
                            Ok thanks a lot, but what language is this code in? I tried entering it into Ruby but it died on the second line... Sorry if i'm being awkward, my programming experience is limited - particularly with SU.
                            • M
                              Metterz
                              I'll be more specific there: it gave me a syntax error message on the second line...
                              • J
                                Jim
                                Sorry about that, I had to hurry off thismorning.
                                The following snippet is still not a full-featured plugin. Everything is hard-coded in the script. You will need to edit the script and restart SketchUp to make any edits effective. It is just a quick example of how to do it.
                                I gave it a menu item in the Plugins menu called "Export corners."
                                UI.menu("Plugins").add_item("Export Corners") do
                                    next unless e.is_a? Sketchup;;Group or e.is_a? Sketchup;;ComponentInstance
                                    bbox = e.bounds
                                    0.upto(7) do |i|
                                      c = bbox.corner(i)
                                    outfile.puts "\n"
                                  outfile.close
                                • M
                                  Metterz
                                  Ok, after entering the first line into the Ruby Console, I got this...
                                  Error; #<SyntaxError; (eval);149; compile error
                                  (eval);149; syntax error
                                  (eval);149
                                  I'm guessing the code isn't intended for Ruby, so where do I enter it to get the plugin working?
                                  • J
                                    Jim
                                    Oh sorry again - I keep making assumptions that people can read my mind.
                                    Here is a file to download and put in your Plugins folder; then restart SketchUp.
                                    export_corners.rb
