    Turn 3D model dimensions into a text file?
    16 Posts 6 Posters 3.7k Views 6 Watching
    • GaieusG
      I am a total non programmer but the collada (*.dae) file SU is capable to export is also a text file (in *.xml format).
      XML format is becoming kind of "popular" nowadays, too. The advantage of it is that even the free version of SU exports it - hidden in the kmz file which is actually a zip file (you can rename it and open it to see within the model folder).
        Jim
        Do you mean simple width, depth, and height information? If so, then you could use Groups to specify each "thing" and export its overall dimensions to a text file.
          Metterz
          Ok there's no way I can afford SU Pro to export anything other than .kmz files. Is it possible to make a text file without exporting files, eg. using Ruby?
            Metterz
            And besides, the program's meant to be written for an end user, so the SU part of the whole thing has to be the freeware version...
            Thanks all for your help
              Jim
              Yes, it's possible, but it's not clear to me exactly what data you need as the output?
                Metterz
                Just a string of numbers will probably do, like maybe co-ords of each corner of each group/component. I just need some text file data that MS Access can use to easily acquire the dimensions of groups/components in a SU file. It will probably easier if I can make an Excel spreadsheet though, instead of a text file.
                I don't know how the contents of the dimensions file will be arranged, but i'll try to work with whatever I can get out of the SU model
                  Jim
                  At a basic level, this will do what you need.
                  outfile = File.new( "c;\\output.csv", "w")
                  Sketchup.active_model.entities.each do |e|
                    next unless e.is_a? Sketchup;;Group or e.is_a? Sketchup;;ConponentInstance
                    bbox = e.bounds
                    0.upto(7) do |i|
                      c = bbox.corner(i)
                      outfile.print "#{c.x.to_f},#{c.y.to_f},#{c.z.to_f}\n"
                    outfile.puts "\n"
                  outfile.close
                    Metterz
                    Ok thanks a lot, but what language is this code in? I tried entering it into Ruby but it died on the second line... Sorry if i'm being awkward, my programming experience is limited - particularly with SU.
                      Metterz
                      I'll be more specific there: it gave me a syntax error message on the second line...
                        Jim
                        Sorry about that, I had to hurry off thismorning.
                        The following snippet is still not a full-featured plugin. Everything is hard-coded in the script. You will need to edit the script and restart SketchUp to make any edits effective. It is just a quick example of how to do it.
                        I gave it a menu item in the Plugins menu called "Export corners."
                        UI.menu("Plugins").add_item("Export Corners") do
                            next unless e.is_a? Sketchup;;Group or e.is_a? Sketchup;;ComponentInstance
                            bbox = e.bounds
                            0.upto(7) do |i|
                              c = bbox.corner(i)
                            outfile.puts "\n"
                          outfile.close
                          Metterz
                          Ok, after entering the first line into the Ruby Console, I got this...
                          Error; #<SyntaxError; (eval);149; compile error
                          (eval);149; syntax error
                          (eval);149
                          I'm guessing the code isn't intended for Ruby, so where do I enter it to get the plugin working?
                            Jim
                            Oh sorry again - I keep making assumptions that people can read my mind.
                            Here is a file to download and put in your Plugins folder; then restart SketchUp.
                            export_corners.rb
