    Need some help creating a rounded cube
    10 Posts 6 Posters 1.3k Views 6 Watching
    • D
      DAE_JA_VOO
      Hi everyone.
      I need to create a cube that has rounded edges. I've tried and i've tried, but i can't seem to get it right. I know that i should use the follow me tool, but i still can't get it right.
      And help please?
      Thanks!
      • soloS
        solo
        Here
        Use the round edge ruby.
        cube with rounded edges.skp
        http://www.solos-art.com
        • soloS
          solo
          forgot the image.
          http://img369.imageshack.us/img369/1727/cubewithroundededgeslr4.jpg
          • D
            DAE_JA_VOO
            Awesome, thanks, but i need to know how to do that. Round edge ruby?
            • soloS
              solo
              404 Not Found
              (www.sketchucation.com)
              • J
                Jim
                Solo, here's an image of the rounded edges I get from using the plugin. Note the difference in the corners where the 3 edges come together. I would prefer the type of corner seen in your image as it appears smoother. Have I missed some option of the plugin?
                • R
                  remus
                  Solo might have been usign the bevel edges ruby, which can be found here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=9406&hilit=+Plugin
                  You could also do it the old fashioned way, as shown here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=18255#p18255
                  • soloS
                    solo
                    Actually I used a 'bevelled cube' from my shape component library, I thought It was the same as the 'curved edge' ruby result.
                    Thanks for pointing that out Jim.
                    • MALAISEM
                      MALAISE
                      Hi DAE_JA_VOO
                      Just another way, have a look on the last Base Camp'video "Tricks and Tips" ,as far as I remember
                      one of ours friends ( Jean Lemire or Gaius. ?) showed how to make a rounded cube on a very similar way as Solo..
                      MALAISE
                      • GaieusG
                        I was only going to but due to the lack of time I couldn't. I believe Jean made one - he was the last of the four of us to present here.
