    Dusty Conditions
    extensions
    12 Posts 3 Posters 1.6k Views 3 Watching
      StarWarsKnower
      I have rendered a basement. I want it to be a bit more dusty. Like I mean you can see the light reflecting off the dust kinda thing, like when you shine a torch in pitch dark, you can see the dust, that exact kind of thing. Any ideas?
      Mike
        You need to create your own materials and/or clipmaps for that. Don't want to do all the hardest things right in the beginning! Go step by step otherwise you will keep being frustrated all the time.
        • FrederikF Offline
          Frederik
          I'm not sure that Gaieus have this right... πŸ˜•
          Do you mean something like this..?? πŸ˜‰
          If Yes, then it's called Volume lightning and you can play with it under the Global fog settings...
          click Settings > Scene...
          You'll now see a window with 3 tabs... (Lights, Cameras and Global Settings)
          Select the Global Settings tab...
          In the Ambient & Volume Lightning field, you need to check that Volume Lightning is ticked...
          In the Global Fog field you just need to adjust the Scatter settings... (you may start with .05 or .1)
          You can find a small scene here, which you can use to play with... πŸ˜‰
          Please note! ❗ Volume lightning will increase your render time significantly... 😐
          Cheers
          Kim Frederik
            I didn't mean that it cannot be done - I was just suggesting to advance step by step. This feature is great (and if I had more powerful machines I could make really nice images in churches) but also, the surfaces won't be dirty/dusty this way.
            πŸ˜„
              StarWarsKnower
              Very cool, thankyou very much!
              Mike
              • FrederikF Offline
                Frederik
                Didn't mean to offend you, Csaba... πŸ˜‰
                And I don't know if this is what Mike is looking for... πŸ˜•
                The above was just a quick render I made using Mike's model for the example...
                And you're right that this won't create dirty/dusty surfaces, but only change the lightning... πŸ˜‰
                Cheers
                Kim Frederik
                  StarWarsKnower
                  And there is the finished product!
                  Mike
                  • FrederikF Offline
                    Frederik
                    Good to see that you're adapting things fast... πŸ˜„
                    But I can see that you're still having an issue with the materials on the drums... πŸ˜‰
                    Cheers
                    Kim Frederik
                      StarWarsKnower
                      Am I? Well erm, I thought they didn't look too bad but. I see what you mean now. I have done another render. Here, it is the same but without the soft shadows. I rather this one. Tommorow morning I will make yet another with fixed textures.
                      Mike
                      • FrederikF Offline
                        Frederik
                        Volume lightning and soft shadows is a bad mix... πŸ˜‰
                        Which also makes sence, since KT is a GI render application... πŸ˜‰
                        Only use one of them at a time... Never together... πŸ˜‰
                        Cheers
                        Kim Frederik
                          I didn't feel offended Kim if this relaxes you πŸ˜‰
                          And yes, cool renders, Mike! I wish I had more time playing with Kerky
                            StarWarsKnower
                            Yeah lol. It's the summer holidays! I've got 6 weeks off school. 😍
                            Mike
