    Dusty Conditions
    extensions
    12 Posts 3 Posters 1.8k Views 3 Watching
    • GaieusG
      You need to create your own materials and/or clipmaps for that. Don't want to do all the hardest things right in the beginning! Go step by step otherwise you will keep being frustrated all the time.
      • FrederikF
        Frederik
        I'm not sure that Gaieus have this right... πŸ˜•
        Do you mean something like this..?? πŸ˜‰
        If Yes, then it's called Volume lightning and you can play with it under the Global fog settings...
        click Settings > Scene...
        You'll now see a window with 3 tabs... (Lights, Cameras and Global Settings)
        Select the Global Settings tab...
        In the Ambient & Volume Lightning field, you need to check that Volume Lightning is ticked...
        In the Global Fog field you just need to adjust the Scatter settings... (you may start with .05 or .1)
        You can find a small scene here, which you can use to play with... πŸ˜‰
        Please note! ❗ Volume lightning will increase your render time significantly... 😐
        Cheers
        Kim Frederik
        • GaieusG
          I didn't mean that it cannot be done - I was just suggesting to advance step by step. This feature is great (and if I had more powerful machines I could make really nice images in churches) but also, the surfaces won't be dirty/dusty this way.
          πŸ˜„
            StarWarsKnower
            Very cool, thankyou very much!
            Mike
            • FrederikF
              Frederik
              Didn't mean to offend you, Csaba... πŸ˜‰
              And I don't know if this is what Mike is looking for... πŸ˜•
              The above was just a quick render I made using Mike's model for the example...
              And you're right that this won't create dirty/dusty surfaces, but only change the lightning... πŸ˜‰
              Cheers
              Kim Frederik
                StarWarsKnower
                And there is the finished product!
                Mike
                • FrederikF
                  Frederik
                  Good to see that you're adapting things fast... πŸ˜„
                  But I can see that you're still having an issue with the materials on the drums... πŸ˜‰
                  Cheers
                  Kim Frederik
                    StarWarsKnower
                    Am I? Well erm, I thought they didn't look too bad but. I see what you mean now. I have done another render. Here, it is the same but without the soft shadows. I rather this one. Tommorow morning I will make yet another with fixed textures.
                    Mike
                    • FrederikF
                      Frederik
                      Volume lightning and soft shadows is a bad mix... πŸ˜‰
                      Which also makes sence, since KT is a GI render application... πŸ˜‰
                      Only use one of them at a time... Never together... πŸ˜‰
                      Cheers
                      Kim Frederik
                      • GaieusG
                        I didn't feel offended Kim if this relaxes you πŸ˜‰
                        And yes, cool renders, Mike! I wish I had more time playing with Kerky
                          StarWarsKnower
                          Yeah lol. It's the summer holidays! I've got 6 weeks off school. 😍
                          Mike
