    Mighty Animation Tool
    39 Posts 10 Posters 8.6k Views 10 Watching
    • K Offline
      kwistenbiebel
      Let us have respect for Plot Paris' thread and get back on topic.
      (Maybe the discussion on the shadow bug can continue in the corresponding thread)
        Mr S
        Well, my original point was that after all the thought and consideration given by Plot Paris towards enhancing SketchUps animation controls it would prove difficult to find or expect anyone to do all that work when the final output could still be let down by the fundamental shadow flaw that exists in SketchUp.
        I don't regard that as going off topic.
        To repeat myself, any new animation controls could only be appreciated when used in conjunction with third party renderers. But could these added controls work well with all the alternatives now available? Wouldn't such an author be overwhelmed with demands for these new animation features to fit in to the workflow of Vray, SU Podium, Fryrender, Kerkthea etc.
        To me, that is the wrong way round.
        The core animation features within SketchUp should work properly, then it would be down to the coders of each individual third party renderer to ensure their own product works correctly with SketchUp.
        I thought I was making a valid point, but I apologise to Plot Paris (and only him) if he feels that I have taken his post in a direction which he didn't want.
        I appreciate all the thought, time and effort he has given this subject.
        Regards
        Mr S
        • plot-parisP Offline
          plot-paris
          Mr S, I completely understand (and share) your anger about the shadow bug.
          but I think, with an animation tool as we dream it here there would be loads of uses, even without SketchUp's shadows.
          and concerning compartibility with render-engines: "In Whaat we trust!" 😉
          @kwistenbiebel:
          oh dear, hundrets of layers - and that was only one camera pan shot! the only way to get a longer animation would probably be to create a new model for each shot. too bad, that indigo doesn't work with it. have to have a look at fry.
          but you proved: with a lot of work (if a longer animation is planned) nice videos can already be produced.
          there is still the question of how to realise more complicated camera motions (flightpath), combined with object animation...
          • K Offline
            kwistenbiebel
            Does this come close?
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=12094
            • DavidBoulderD Offline
              DavidBoulder
              Thought of an interesting idea for how to animate objects?
              I can have one camera path for stationary objects, and would make this like a normal movie.
              Then I could animate objects that move one at a time (or at least ones that share same movement). For this to work the camera path needs to be adapted not just to follow the original camera path but to compensative for the movement of the object. (Maybe new flightpath version?) So at least on the mac PNG is option for image export. I could layer my base animation, and then a layer for each object animation path. And I would be done. OK, little glitch here, though, if my animated objects won't go behind model objects with this setup. OH, well.
              By the way, I do agree, for me to use advanced animation inside of SketchUp I really do need shadows to work in one form vs. another (eg. baked)
              David Goldwasser
              OpenStudio Developer
              • K Offline
                kwistenbiebel
                David,
                Su Animate does what you mention above.
                You can draw several paths: 1 for camera position , 1 for camera target, and different motion paths for objects (groups). You have control over the speed (=by number of segments in the path curve) and you can also setup a delay. You can assign more than one path to an object (or camera) resulting in more complex motion behaviour etc...
                  plot-paris
                  well, that is exactly the type of animation that I had in my mind!
                  now lets pack this in the proposed user interface and find another way of saving the animation (I refer to suanimate here, where you will have a layer and a scene tab for every frame of the animation - just imagine you have a 5 min video... 7200 frames; and as many layers/scenes 😄 )
                    remus
                    I wonder if theres an internal layers/scenes limit in SU? Could put a stopper on any serious film making exploits.
                    • K Offline
                      kwistenbiebel
                      @Plot Paris,
                      Here's another idea:
                      I know there is free ruby on the Smustard website called 'CameraLines.rb' that makes a line path out of the scene tabs you created (= the default SU method creating them).
                      http://www.smustard.com/script/CameraLines
                      The ruby creates a set of connecting lines.
                      Now if someone could make a ruby that would convert those lines in a smooth bezier curve by interpolation and add control points to the curve for editing, we could have a really smooth path creator to be used both in combo with the flightpath2 ruby (which you seem to use) as the SuAnimate plugin.
                      In that way, we could start setting up our animation as we would do traditionally by creating default scene tabs with interpolated transitions and go from there to make it a bezier path which we can alter and refine.
                        plot-paris
                        great idea.
                        and in addition to that (maybe version 1.2 of the script) a second path is created for the camera aim. this is a bit more tricky because you don't have a definite position of that aim. but surely there is a way to automate the process.
                        should we make a ruby request?
                        • K Offline
                          kwistenbiebel
                          Maybe we could start with making a request for a 'camera-to-editable-bezier' ruby, and take it from there.
                            plot-paris
                            wow, I just discovered, that CameraLine creates a straight line in the direction of the camera focus for every scene. so we have that information as well.
                            I just tried to create a cubic bezier curve for the camera motion by placing a control point at every camera position; and another curve in the same manner for the focus.
                            it works quite good. allthough the curve cam be very flamboyant and unpredictable, if you have only a few scenes.
                            but surely one can develope an algorythm or a procedure, that keeps the curve closer to the original camera path (like inserting additional control points close to the left and to the right of each camera position). oh yes, that could even be a parameter for the tool - defining the smoothness of the curve...
                            http://img399.imageshack.us/img399/605/campathsq7.jpg
                            • K Offline
                              kwistenbiebel
                              Hi Jakob,
                              Anybody uses 'SU Animate' or 'Presentation tools' to make their animations?
                              somehow there is not a lot of info on this forum about these plugins.
                              Maybe that is because they are commercial and haven't got demos so not enough people are using it.
                              As I am not familiar with those plugins, I decided to download a SU demo scene from the SU animate site containing an object animation combined with a camera animation.
                              Just to see how it would look like, I rendered it using fryrender.
                              The result is promising, but very choppy.
                              SU animate in essence automates the 'classic' SU layered animation principle, which means that per frame a layer gets visible while all others get hidden.
                              Some observations:
                              the camera animation is fluent, while the object animation is very choppy.
                              Probably because objects aren't animated the same way as cameras.
                              In order to have fluent animation using the 'hidden layer' method, one needs the same number of scenes as there are frames in the animation. Since the object is either 'visible' or 'not visible', SU needs to create a very large amount of scenes.
                              Clearly object animation should work the same way as camera animation with interpolated frames in between scenes.
                              [EDIT]: I found a way to overcome the 'choppyness': you can get a better framerate when dividing the object path into more pieces. The number of segments in the curve defines the number of animation frames. To get smooth animation, one would need 30 frames per second, so 30 segments in the path curev will represent 1 second of animation.
                              • K Offline
                                kwistenbiebel
                                Looks interesting Jakob.
                                An advanced Bezier editing tool set sure would come in handy.
                                I must say Fredo6 already did a fine joob on current Bezier toolbar, but towards animation paths indeed things could be refined.
                                Another thing in this thread that wasn't mentioned yet and which most other animation packages (C4D, Max, etc..) is a graph editor for speed control. The current segment count of the Bezier animation paths is difficult to alter currently, especially if you want to be able to speed up or speed sown an object/camera in a smooth way.
                                • K Offline
                                  kwistenbiebel
                                  And another animation wish: Real world physics!
                                  I hope The upcoming Sketchyphysics version will support scene tab animations.
                                  It sure would make my balls bounce better 😄 .
                                  (SU-animate + Fry render):
                                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/botsend_1_4.gif
                                    Bruell
                                    I like your Reel on the bottom of the window. I think, to have a simple way of managing multiple cameras with this could be that near the left arrow you would have a drop down menu for the different cameras. Just a small arrow that opens the drop down for your camera pick.
                                    And then here another idea, SU should definitely let one use multiple views just like 3D max and you could switch with a shortcut or the rmb on the frame then o activate one window or many.
                                    Oh don't want to forget the praise over your great work man!
                                      plot-paris
                                      impressive, I just rediscovered the "film & stage" plugin (for SketchUp 5). that is really a useful script. and it allready gives us the opportunity to work with a physical model of a camera as would be ideal for the Mighty Animation Tool.
                                      it is really great; you can either move the model of the camera or you can enter the camera view and change it's position by choosing the view, you like.
                                      if you did that at key frames and the animation tool interpolates the camera motion inbetween, this is the perfect way of managing a camera.
                                      if you then have additional control over the interpolation via bezier curve, it would be a dream!!!
                                        Bruell
                                        Have a look at this from Auto Desk Auto Cad 2009 How to,s "SHOW MOTION", looks pretty useful.
                                        I would like to add a "no clipping" mode plus the navigation trough "w;a;s;d; keys.
                                        http://resources.autodesk.com/autocad/How_Tos
                                          plot-paris
                                          I would also like to see the "view cube tool" in the top right corner of the screen. makes navigating easier than it currently is with SketchUp's standart views.
                                          great idea about the "no clipping" mode. so the Mighty Animation Tool would automatically alter the camera path in order not to get too close to surfaces within the view window.
                                          • 2 / 2
