    Mighty Animation Tool
    39 Posts 10 Posters 9.4k Views 10 Watching
      kwistenbiebel
      Hi Jakob,
      Rendering object animations using PR render software IS possible from within Sketchup. 😉
      See example using fryrender:
      Link for direct view:
      http://www.vimeo.com/1545109
      [flash=640,480:bp92c3ga]http://www.vimeo.com/moogaloop.swf?clip_id=1545109&server=www.vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:bp92c3ga]
      For those preferring youtube:
      http://www.youtube.com/watch?v=0LO3seJv0ik
      Wanna know how I did it ? 😄
      • plot-parisP Offline
        plot-paris
        what a great animation, kwistenbiebel!
        convincing sound effects that bring the whole thing to live. but what really impressed me was your fade from black and white ("wow, rail tracks crossing wide water surface") to coloured ("oh, its not water - its wood!" 😮 ).
        How did you do it? which animation tool did you use?
          Mr S
          A more versatile and professional animation addition to SketchUp as you suggest would be most welcome.
          But while the shadow bug (still not fixed after 9 years) is still present why would anyone waste all their time and effort on producing something like this.
          What would be the point of enabling us to produce better animations with these new tools only for the final output to be ruined by the horrible mess of the SketchUp shadows.
          Some may take the view that animations can be produced without shadows. Whats the big problem? But Sketchup Pro is supposed to be a professional 3D application.
          Shadows form an important part of 3D work and as part of a profeassional application should work correctly.
          To me, this situation is a bit like Adobe saying Photoshop is a professional 2D editing application but it doesn't work correctly with JPG files. But don't worry, you can work around this by using other file types. Madness!
          The addition of better animation tools would only be of use if seamlessly intergrated to work with third party renderers such as Vray, Fryrender, SU Podium etc.
          Regards
          Mr S
            kwistenbiebel
            @mr s said:
            What would be the point of enabling us to produce better animations with these new tools only for the final output to be ruined by the horrible mess of the SketchUp shadows?
            Indeed, good point.
            Personally I just want to use photoreal render software on Sketchup scene tab animations.
            The shadow bug doesn't affect this.
              johnsenior1973
              @mr s said:
              Regards
              Mr S
              Are you going to be stamping your feet in a tantrum on a regular basis over the shadow bug? Maybe if you cry or wet your pants while you do it Google will be forced to act.
                plot-paris
                I would wet my pants right here in the office if that fixed the shadow bug! 😄
                but as you said, Mr S, as long as we can export the animation to external render applications (Indigo! I love it!!! 😉 ), such a tool would be a great enhancement
                PS: kwistenbiebel, how did you do your animation export to fry? (I'll keep on asking 😉 )
                  kwistenbiebel
                  Straight from within Sketchup 😄
                  The object animation in SU is basically a scene tab animation with as much scene tabs as there will be animation frames(=hundreds 😉).
                  I set the 'transition times' in SU to 1 second (delay=0).
                  In the Fry 'render settings' panel, I set the framerate of the animation to be 1 FPS.
                  When clicking the Fry render button from within SU, a fluent animation will be generated, rendering each scene tab as an animation frame.
                  SUanimate is a cool plugin for object animation. Basically it automates the traditional 'layer visibility' animation method, spreading the animation frames over different scene tabs, each with their own visible layer (each layer has a different object location).
                  Fryrender does a wonderful job rendering the moving objects and camera.
                  Skindigo however doesn't take 'layer visibility' into consideration when exporting animation.
                  As a result, the Indigo animation won't show object motion.
                    Mr S
                    To "johnsenior1973"
                    Perhaps if more stamp their feet over this issue then maybe, just maybe, Google may decide to make it a priority to fix it. I have found that nowadays that unless you are prepared to make a lot of noise about something it is hoped that you and your complaint will just go away.
                    However, if I, and others do manage to persuade Google to act on this issue (I may just wet my pants if that happens) then you can just enjoy the benefits.
                    I would not keep banging on about this if SketchUp was still owned by AtLast. They were a small company with limited resources. Google is the exact opposite.
                    If they really wanted to solve this problem they have everything at their disposal to do so.
                    If you are happy with the situation and have nothing positive to contribute then why not just keep quiet?
                    Regards
                    Mr S
                      kwistenbiebel
                      Let us have respect for Plot Paris' thread and get back on topic.
                      (Maybe the discussion on the shadow bug can continue in the corresponding thread)
                        Mr S
                        Well, my original point was that after all the thought and consideration given by Plot Paris towards enhancing SketchUps animation controls it would prove difficult to find or expect anyone to do all that work when the final output could still be let down by the fundamental shadow flaw that exists in SketchUp.
                        I don't regard that as going off topic.
                        To repeat myself, any new animation controls could only be appreciated when used in conjunction with third party renderers. But could these added controls work well with all the alternatives now available? Wouldn't such an author be overwhelmed with demands for these new animation features to fit in to the workflow of Vray, SU Podium, Fryrender, Kerkthea etc.
                        To me, that is the wrong way round.
                        The core animation features within SketchUp should work properly, then it would be down to the coders of each individual third party renderer to ensure their own product works correctly with SketchUp.
                        I thought I was making a valid point, but I apologise to Plot Paris (and only him) if he feels that I have taken his post in a direction which he didn't want.
                        I appreciate all the thought, time and effort he has given this subject.
                        Regards
                        Mr S
                          plot-paris
                          Mr S, I completely understand (and share) your anger about the shadow bug.
                          but I think, with an animation tool as we dream it here there would be loads of uses, even without SketchUp's shadows.
                          and concerning compartibility with render-engines: "In Whaat we trust!" 😉
                          @kwistenbiebel:
                          oh dear, hundrets of layers - and that was only one camera pan shot! the only way to get a longer animation would probably be to create a new model for each shot. too bad, that indigo doesn't work with it. have to have a look at fry.
                          but you proved: with a lot of work (if a longer animation is planned) nice videos can already be produced.
                          there is still the question of how to realise more complicated camera motions (flightpath), combined with object animation...
                            kwistenbiebel
                            Does this come close?
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=12094
                            • DavidBoulderD Offline
                              DavidBoulder
                              Thought of an interesting idea for how to animate objects?
                              I can have one camera path for stationary objects, and would make this like a normal movie.
                              Then I could animate objects that move one at a time (or at least ones that share same movement). For this to work the camera path needs to be adapted not just to follow the original camera path but to compensative for the movement of the object. (Maybe new flightpath version?) So at least on the mac PNG is option for image export. I could layer my base animation, and then a layer for each object animation path. And I would be done. OK, little glitch here, though, if my animated objects won't go behind model objects with this setup. OH, well.
                              By the way, I do agree, for me to use advanced animation inside of SketchUp I really do need shadows to work in one form vs. another (eg. baked)
                              David Goldwasser
                              OpenStudio Developer
                              National Renewable Energy Laboratory
                                kwistenbiebel
                                David,
                                Su Animate does what you mention above.
                                You can draw several paths: 1 for camera position , 1 for camera target, and different motion paths for objects (groups). You have control over the speed (=by number of segments in the path curve) and you can also setup a delay. You can assign more than one path to an object (or camera) resulting in more complex motion behaviour etc...
                                  plot-paris
                                  well, that is exactly the type of animation that I had in my mind!
                                  now lets pack this in the proposed user interface and find another way of saving the animation (I refer to suanimate here, where you will have a layer and a scene tab for every frame of the animation - just imagine you have a 5 min video... 7200 frames; and as many layers/scenes 😄 )
                                    remus
                                    I wonder if theres an internal layers/scenes limit in SU? Could put a stopper on any serious film making exploits.
                                      kwistenbiebel
                                      @Plot Paris,
                                      Here's another idea:
                                      I know there is free ruby on the Smustard website called 'CameraLines.rb' that makes a line path out of the scene tabs you created (= the default SU method creating them).
                                      http://www.smustard.com/script/CameraLines
                                      The ruby creates a set of connecting lines.
                                      Now if someone could make a ruby that would convert those lines in a smooth bezier curve by interpolation and add control points to the curve for editing, we could have a really smooth path creator to be used both in combo with the flightpath2 ruby (which you seem to use) as the SuAnimate plugin.
                                      In that way, we could start setting up our animation as we would do traditionally by creating default scene tabs with interpolated transitions and go from there to make it a bezier path which we can alter and refine.
                                        plot-paris
                                        great idea.
                                        and in addition to that (maybe version 1.2 of the script) a second path is created for the camera aim. this is a bit more tricky because you don't have a definite position of that aim. but surely there is a way to automate the process.
                                        should we make a ruby request?
                                          kwistenbiebel
                                          Maybe we could start with making a request for a 'camera-to-editable-bezier' ruby, and take it from there.
                                            plot-paris
                                            wow, I just discovered, that CameraLine creates a straight line in the direction of the camera focus for every scene. so we have that information as well.
                                            I just tried to create a cubic bezier curve for the camera motion by placing a control point at every camera position; and another curve in the same manner for the focus.
                                            it works quite good. allthough the curve cam be very flamboyant and unpredictable, if you have only a few scenes.
                                            but surely one can develope an algorythm or a procedure, that keeps the curve closer to the original camera path (like inserting additional control points close to the left and to the right of each camera position). oh yes, that could even be a parameter for the tool - defining the smoothness of the curve...
                                            http://img399.imageshack.us/img399/605/campathsq7.jpg
                                            • 2 / 2
