    Updated avi output
    4 Posts 3 Posters 1.5k Views 3 Watching
    • A
      artwhore
      I bought Pinnacle 12 video editor a while ago and it doesnt recognize the sketchup avi. I dont know much about this but apparently there is more than one kind of avi.
      I have to run my sketchup avi files through a converter before I can edit them in pinnacle.
      So.. my wish is for more/newer/updated avi output.
      Pat
      • GaieusG
        Hi Pat,
        Now I'm not sure if I1m correct but SU uses the video converters (codex'- hm... "codices") that you have on your machine installed (you can choose from a variety of them in the animation export options).
        Anyway, for finer output I'd use uncompressed videos (like mpg) or even uncompressed series of still images and use that for a final tweaking in your video editor. Most of the quality editors will make better output than SU with the codices ( ❓ Do you use the Latin plural for this term as well ❓ )
        • A
          artwhore
          Hi Gaieus
          Thanks for the reply. I guess im going to have to read up on all the different codex('S?)
          as for outputting to mpg, I thought avi was the only output option from sketchup.
          I know I should research this alot more, but working at home with a toddler in the house, i'm lucky to just get my work done.
          Thanks again
          Pat
          • R
            remus
            When your choosing the save location for the animation you should be able choose what you want to export to in a little drop down menu underneath the save loaction.
            On a slight side note, i didnt have .mpg as an option, only jpg, png, tif, bmp and avi. Is it broken?
