    EPS import into Layout
    layout
    3 Posts 2 Posters 2.3k Views 2 Watching
    • F Offline
      fakircho
      Hi guys
      I alternate between Indesign and Layout to for design presentation layouts.
      I would use Layout more if could bring my CAD drawings to scale using the EPS format.
      I can do that perfectly in Indesign and the scale remains accurate. I would really like this
      functionality in layout.
      So in short i want to see Layout be able to import EPS files πŸ˜„
      • DavidBoulderD Offline
        DavidBoulder
        FYI currently on Mac (but not PC) you can import PDF. So if you convert your EPS to PDF you can bring it in. But won't provide the quality of InDesign. When I have had PDF's for Layout, I found I got better quality by rasterizing myself in Photoshop and importing as an image.
        David Goldwasser
        OpenStudio Developer
        • F Offline
          fakircho
          Thanks for the info. I mainly use Sketchup at the office and that is in Windows. I will play around with the PDF import in OSX at home πŸ˜„
