    Problems with RPS 3D PDF
    extensions
    1 Posts 1 Posters 592 Views 1 Watching
    • Al HartA Offline
      Al Hart
      I am running the trial of 3D-PDF using version 6 of Sketchup Pro and Windows XP SP3.
      I have found that I get different results if I run from an export 3D and putting the *.skp file through 3D-PDF! The latter gives best results but does not reproduce section views. Running 3D-PDF using export 3D from Sketchup results in errors with the positioning of texture files and no user generated views are made nor are any section views created. Am I doing something wrong please? Otherwise, this is just what I want to be able to send my clients PDF files of their Sketchup models!
      Our PDF programmer is on vacation until Thursday.
      However, send us a (preferably small) SKP model, and the 2 PDFs you are creating - from 3D export, and from the stand-alone 3D PDF and we will try to figure out what is wrong.
      I am posting this on the forum as well, so others can read the response and perhaps make comments.
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
