    Rendering plugins?
    11 Posts 7 Posters 1.9k Views 7 Watching
      timetodoit
      Hi there, I'm a graphic designer that just started using sketchup it's really handy for some stuff that I need to make and then "treat" in photoshop.
      But the current render is very very bad.. Is there something better? I use a mac!
      Free would be awesome
        remus
        theres a list for render engines available for SU here, out of those id recommend podium as a good one to start with (theres a free version thats limited to 500x500 output, but the full version is only 200 dollars or so.)
        If your feeling a bit more keen indigo is definetly worth checking out. Bit more of a learning curve in terms of what everything does, but it can produce fabulous renders.
        If you feel like forking out a bit of cash v-ray is also very good, similar quality images to indigo but faster. More of a learning curve though.
          timetodoit
          I see that podium only works on Windows
          I need a one that works on a Mac
          • soloS Offline
            solo
            The Podium Mac version is in beta testing at moment and will be available very soon (a couple weeks I believe)
            http://www.solos-art.com
              remus
              Beta me to it solo.
              • FrederikF Offline
                Frederik
                None of the render applications you've mentioned are available for Mac, Remus... 😐
                And you didn't even mention Kerkythea, which is available for Mac... 😒
                Download the Getting Started - KT2008 Echo tutorial, for a quick introduction... πŸ˜‰
                But if you need help, you can always search in the KT Forum or post your question - if any... πŸ˜„
                Cheers
                Kim Frederik
                  remus
                  Very true frederik, i read the post too quickly.
                  As frederik says kerkys got a mac version and is a very capable render engine πŸ‘
                    timetodoit
                    Thank you guys I will give that one a try! πŸ˜„
                    • AdamBA Offline
                      AdamB
                      And you could try LightUp too. Its a free demo on both Mac and Windows and available here.
                        troyhome
                        I'm on a Mac and I have good luck with Maxwell Render, but it's $$y.
                        I have yet to try Vray for SU on Mac... seems to do a good job on the PC, but I can FIND a trial for Mac so i haven't tried it yet.
                        IOviz.com
                        SU Pro 2024 PC
                        • pbacotP Offline
                          Hi Timetodoit.
                          Since you are using Photoshop see http://sites.google.com/site/3dbasecamp2008/all-sessions-2008/taking-your-models-into-photoshop
                          on how to "render" in PS.
                          Yes printing straight from SU is rough. But also have you tried exporting .png at high resolution and printing that? Still not a rendering but much cleaner.
                          I am looking, like yourself, and checked out Kerkythea, but this is not so simple as loading a Mac app on your Mac. Stopped me, until I can spend time loading and learning the software needed to run it. Looking forward to the Mac Podium.
