Rendering plugins?
Hi there, I'm a graphic designer that just started using sketchup it's really handy for some stuff that I need to make and then "treat" in photoshop.
But the current render is very very bad.. Is there something better? I use a mac!
Free would be awesome
theres a list for render engines available for SU here, out of those id recommend podium as a good one to start with (theres a free version thats limited to 500x500 output, but the full version is only 200 dollars or so.)
If your feeling a bit more keen indigo is definetly worth checking out. Bit more of a learning curve in terms of what everything does, but it can produce fabulous renders.
If you feel like forking out a bit of cash v-ray is also very good, similar quality images to indigo but faster. More of a learning curve though.
I see that podium only works on Windows
I need a one that works on a Mac
The Podium Mac version is in beta testing at moment and will be available very soon (a couple weeks I believe)
Beta me to it solo.
None of the render applications you've mentioned are available for Mac, Remus...
And you didn't even mention Kerkythea, which is available for Mac...Download the Getting Started - KT2008 Echo tutorial, for a quick introduction...
But if you need help, you can always search in the KT Forum or post your question - if any... -
Very true frederik, i read the post too quickly.
As frederik says kerkys got a mac version and is a very capable render engine
Thank you guys I will give that one a try!
And you could try LightUp too. Its a free demo on both Mac and Windows and available here.
I'm on a Mac and I have good luck with Maxwell Render, but it's $$y.
I have yet to try Vray for SU on Mac... seems to do a good job on the PC, but I can FIND a trial for Mac so i haven't tried it yet. -
Hi Timetodoit.
Since you are using Photoshop see http://sites.google.com/site/3dbasecamp2008/all-sessions-2008/taking-your-models-into-photoshop
on how to "render" in PS.Yes printing straight from SU is rough. But also have you tried exporting .png at high resolution and printing that? Still not a rendering but much cleaner.
I am looking, like yourself, and checked out Kerkythea, but this is not so simple as loading a Mac app on your Mac. Stopped me, until I can spend time loading and learning the software needed to run it. Looking forward to the Mac Podium.
