    [REQ] Magic Wand
    12 Posts 6 Posters 3.4k Views 6 Watching
    • RayOchoaR Offline
      RayOchoa
      i was wondering if anyone thought it was possible to do the effect photoshop has. Like to select a color and make a line boundary around it. Like for tracing blueprints. I hope the the ruby masters know what im talking bout
      CaR DeSiGnS bY mE
      http://ray-ochoa.com
        RickW
        I guess we don't...
        Any more (or different) explanation of what you want to accomplish? Images often help get the point across.
        RickW
        www.smustard.com
        • RayOchoaR Offline
          RayOchoa
          If your familiar with photoshop you would know what im talking about. a tool like the magic wand or quick selection is what i mean. It would make it so much easier when tracing blueprints
          http://beckerexhibits.wustl.edu/3D/images1/magicwand.jpg
          CaR DeSiGnS bY mE
            tomsdesk
            Interesting idea, Ray...in the meantime, can't you turn your PS selection into a path and export that as a dxf? (Though I think controling the number of line segments would be impossible...?)
            2.5D Trees & Shrubs!
            • Didier BurD Offline
              Didier Bur
              No. What do you want exactly ? A selection tool ? If so, tthe magic wand of PS is typically useful for bitmap and pixels operations. I can't figure out how such a tool (if ever it was scriptable) could be useful in SU 😮
              For me, what you describe can be achieved with "select by material" or something similar.
              DB
                tomsdesk
                Guys...I'm thinking he wants to import an image into SU, select a color on the image (like in PS) then turn the selection outline into edges and a face. Would be useful, but again I think the edges would be way too segmented.
                I'm wondering if there would be a way to trace one side of a wall (or the centerline) then have a ruby that would offset the edges, close the ends, and create a face...? Right now I do something similar in autocad: with a polyline I offset the width of the wall, then close the ends manually. This I import into SU, then make the faces.
                If I'm off base, Ray, sorry.
                  Didier Bur
                  OK, I see now...
                  I'm afraid there is no way to do that with the actual API.
                  @tomsdesk: there at plenty of sctipts to draw walls at my site, in the "architecture" section.
                  DB
                  • RayOchoaR Offline
                    RayOchoa
                    if a line has too many segments i can fix that. But it would be awsome if i could put the number of lines in the little white box in the corner
                    CaR DeSiGnS bY mE
                    • plot-parisP Offline
                      plot-paris
                      Tom is right. you can do that with photoshop and illustrator. use the magic wand in photoshop, save the selection as a path, export this path to illustrator, save it as a dwg-file, import the dwg-file into SketchUp.
                      I know, quite a detour. but for it can't be done within SU via ruby script it is defenitely better than tracing it manually with the SketchUp drawing tools.
                      makes especially sense when you want to create 2D trees with accurate shadows...
                        tomsdesk
                        If you have Corel PhotoPaint you can export the path directly as a dxf :`)
                          Ah, thanks Tom, I didn't know that (I use that instead of PS)
                          • RayOchoaR Offline
                            RayOchoa
                            ill try that too thx. it would be really nice if there was a way to make an application that could do all this with one click directly into sketchup
                            CaR DeSiGnS bY mE
