    SketchyPhysics Question
    8 Posts 3 Posters 1.2k Views 3 Watching
    • A
      ArchieB
      I am new here and would like a little advice. I have used SketchUp for about a month and have a pretty firm grasp on how to use it. i found sketchy physics downloaded it and became acquainted with the controls pretty quickly i have been able to animate simple objects but they run for about 5 seconds and no matter where the object is it stops moving and i didn't accidentally hit the pause button because this happens every time i use sketchy physics probably simple fix i just can't figure it out?
      • C
        CPhillips
        Post the model and I'll have a look.
        • A
          ArchieB
          I tried moving the car around and starting it in different locations and it's not so much as a time limit it just stops when ever it feels like. could be the car thing i put together quickly or the ramp i don't know.
          Thanks for the help.
          this is it not much but it a stepping stone.
          • C
            CPhillips
            The wheels are square. You need to go into the Wheel/Joint group and set the shape of the wheel to be Convex
            • A
              ArchieB
              I knew it would be something stupid.
              by the way is there a limiter so the objects don't go flying for infinity.
              • C
                CPhillips
                Not sure what you mean.
                  As soon as object are not over a solid floor they fly toward a limit bottom down πŸ˜‰
                  If you want to stop it place some blocks on the limit of "univers"
                  Load this model and have fun 😎
                  • A
                    ArchieB
                    Thanks because i wasn't sure if their was a distance limiter or my laptop was having a hard time processing what was going on.
