    Texture removal
    5 Posts 4 Posters 686 Views 4 Watching
    • R
      ridix
      How do you remove texture from surface?
      • R
        remus
        right click->entity info then mess about with the little materials window in there, i cant remeber the exact combination of buttons you need to press to ge it to set back to default.
        • R
          Ross Macintosh
          I typically do it by repainting the surface using the default material.
          The screenshot below should give some clue as to how you make the 'default' the active paint selection.
          Regards, Ross
          • boofredlayB
            boofredlay
            ridix, I do exactly as Ross said above for single faces.
            However if you want to remove the materials from a whole mess of materials at once you can use the "Remove Materials" script by Todd Burch found Here.
            Install the plugin, then select all the faces you want to remove materials from and then run the script.
            • R
              ridix
              Man, I was deleting the surface to get the materials off! Thanks, both method works fine.
