    Push Pull several coplanar surfaces ?
    8 Posts 4 Posters 952 Views 4 Watching
    • MALAISEM
      MALAISE
      Hello everybody,
      single question: Using Push-Pull Tool ,is it possible to work simultaneously on
      coplanare but separated faces ?
      Here a drawing for a better understanding :
      MALAISE ❓
      • R
        remus
        I dont think so, alth jean lemerier came up with a good work around, i cant remeber where it is though 😉
        • Alan FraserA
          Alan Fraser
          There are a couple of ways you can do that. It is possible to select the surfaces and then use Vector Push/Pull (using the Normals tool). But, on the whole, it is easier simply to Push/Pull one of the surfaces in the normal way, then double-click on the other surfaces...the amount of the first extrusion is held in memory, so they will rise the same distance.
          3D Figures
          • MALAISEM
            MALAISE
            Thxs for the replies.
            I completely forget the plugin. Nice trick, Alan the double click !
            MALAISE 👍
            • Jean LemireJ
              Jean Lemire
              Hi Malaise, hi folks.
              See attached SU file for ideas.
              This is a slightly improved new version of the previous one I posted a while ago.
              Pulling multiple shapes 2.skp
              • MALAISEM
                MALAISE
                Thxs Jean (Johnny)
                I'll open your file very soon. 👍 👍
                MALAISE
                ( Where is located Richelieu ?)
                • Jean LemireJ
                  Jean Lemire
                  Richelieu is about 40 kilometers or 25 miles south east of Montreal.
                  Best regards.
                  • MALAISEM
                    MALAISE
                    Hi ! Jean
                    that's fine, now I see exactly where's your home 👍 👍
                    MALAISE
