Push Pull several coplanar surfaces ?
Hello everybody,
single question: Using Push-Pull Tool ,is it possible to work simultaneously on
coplanare but separated faces ?Here a drawing for a better understanding :
MALAISE
I dont think so, alth jean lemerier came up with a good work around, i cant remeber where it is though
There are a couple of ways you can do that. It is possible to select the surfaces and then use Vector Push/Pull (using the Normals tool). But, on the whole, it is easier simply to Push/Pull one of the surfaces in the normal way, then double-click on the other surfaces...the amount of the first extrusion is held in memory, so they will rise the same distance.
Thxs for the replies.
I completely forget the plugin. Nice trick, Alan the double click !
MALAISE
Hi Malaise, hi folks.
See attached SU file for ideas.
This is a slightly improved new version of the previous one I posted a while ago.
Thxs Jean (Johnny)
I'll open your file very soon.
MALAISE
( Where is located Richelieu ?) -
Richelieu is about 40 kilometers or 25 miles south east of Montreal.
Best regards.
Hi ! Jean
that's fine, now I see exactly where's your home
MALAISE
