    Round edges TWICE...please help!
    11 Posts 7 Posters 1.2k Views 7 Watching
    • B
      Borat
      Hello,
      I would like to further round edges on the cubic shape. Pic will help, you see bottom half is nicely rounded, but would like to round it from above too / you can see I already drew curve...must merge...it is sth like a ship's point...thanks!
      http://img165.imageshack.us/img165/7603/picture14da5.png
      http://img165.imageshack.us/img165/7603/picture14da5.a2ad816c19.jpg
      • R
        remus
        You might want to check out the round edges by bezier plugin in the ruby forum, i imagine it can do what you want.
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10370&hilit=+Plugin
        • B
          Borat
          First thanks for reply. I downloaded and installed, looked at pdf and tried, but it is not that straightforward and does not what I need to do / don't get me wrong, I'm sure for someon it is very easy, can I get some direct advice please? Thanks!
          • B
            Borat
            just wondering, is this so hard to do really? I mean you can push that top down, but only to where the bottom roudness begins.
            Can't define other points to do it...
            • A
              alpro
              Have a look here http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=3631&p=43237&hilit=+dave#p43237
              Mike
              • B
                Buzzer1001
                It's easiest to get the prow shape before you fillet your edges - then you can just do a FollowMe to the whole shape
                • B
                  Borat
                  still struggling...would anyone please gimme tutorial on this? thanks!
                  • D
                    dylan
                    Borat, take a look at this very good tutorial created by Dave R, it should tell you what you need to know.
                    Radiused Cube
                    http://dmdarchitecture.co.uk/
                    • B
                      Borat
                      I did, thanks. but it is confusing getting it into my object...problem is drawing prow shape is very simple, also rounding edges, but not both as one affects the other...so if someone can spare a minute...
                      • TaffGochT
                        TaffGoch
                        Borat,
                        You don't mention whether you tried Buzzer1001's suggestion. Did you miss it (or discount it)? It really works quite well.
                        Taff
                        "Information is not knowledge." -- Albert Einstein
                        • B
                          Borat
                          thank you all. found the way, comvining some of these tips! like radius cube etc.
