    JPEG images
    4 Posts 4 Posters 685 Views 4 Watching
    • M
      MasterWorks
      Only having used SketchUp 2 - 3 times prior to now.
      Have JPEG image of a raised panel cabinet door.
      Want to produce outline of door & it's panel.
      I can't seem to get any tools to operate in the image.
      Do I need to change the image into something else so SketchUp will operate on it?
      Thanks for your patience & understanding,
      dlb
      • ely862meE
        ely862me
        no u don t need
        maybe u should atach the image here
        u can use the line tool and push and pull tool
        Elisei
        Elisei (sketchupper)
        Come and See EliseiDesign
        • M
          Marlise
          MasterWorks, after you import the JPG from the File menu, context click (right mouse click) on it and choose Explode. Then the tools will work just fine.
          Wow, I finally know at least something. Have fun with your learning, and (as Gaieus will tell you), read the PDF manual.
          --Marlise
          • GaieusG
            I hope, Marlise, you did not tka that offensive that time! (As you know I didn't mean it that way) πŸ˜‰
